E34 (1989 - 1995)
Old 10-20-2012, 02:31 PM
mav99 mav99 is offline
Mein Auto: 1995 525i
Unhappy My 5 Fuse blooooows !!!!!!!! Help !!!!
Hello!!!
#5 fuse keeps blowing
Dashbord light is out
Front parking light is out
Rear parking light is out
Now I am going to blow my brains out !!!
I have replaced all the bulbs in the dash cluster (cluster works) front right and back right.
Directionals work parking lights dont.
I replaced the headlight switch and dimmer switch on the left side of the dash.
What Gives ?
Old 10-20-2012, 06:29 PM
supertech777's Avatar
supertech777 supertech777 is offline
Originally Posted by mav99 View Post
Hello!!!
What Gives ?
electrical problems are pretty hard to diagnose over the net , I would suggest back tracking your work , a wire has got to be pinched when you where in the process of putting it back together . Unless you had that problem before you worked on it .
Old 10-20-2012, 06:42 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Possiable your wattage has increased ,reversed connection at a lamp,possible damaged socket would do it too.
Old 10-21-2012, 01:30 AM
BMWFatherFigure's Avatar
Old School
Start a careful examination of ALL the parts you touched.
Current:
Previous:
Old 10-21-2012, 02:51 AM
Banned
Mein Auto: car
Hello!!!
What Gives ?
This might be silly but just in case, are you using a fuse of the correct rating for #5 ?
Old 10-21-2012, 10:07 PM
Mein Auto: 1989 525i M20B25
If its not any of the above then you need to see if you have the correct bulb in the front indicator.
If it is a single contact bulb it will short the two contacts in the socket and blow the fuse like you say.
