E46 (1999 - 2006)
Old 10-19-2012, 09:13 PM
Put325i Put325i is offline
Mein Auto: 2003 325i
Question Weird noises from engine
I had the valve cover gasket replaced and i power washed the whole engine with some degreaser to clean the leaked oil. after all this my engine makes this weird noise and a friend said it was the pcv valve but it can also be the belt tensioner. also after you shut off the engine it makes this suction it never made before. Any ideas as to what it is? thanks in advance!
Old 10-19-2012, 09:19 PM
also forgot to add that if you take off the oil cap, the noise goes away a little bit and if you put your hand over the hole it has a slight suction.
Old 10-22-2012, 06:41 AM
ahull's Avatar
ahull ahull is offline
That's your crankcase vent valve CCV/oil separator. I think it's normal to sound like this - all it is doing is releasing the vacuum after the engine shuts off. Mine has sounded like that for years. When it starts to sound like a foghorn or dying sheep, then it's gunked to the point of needing to be replaced, usually between 60k and 100k miles on the clock.
Light suction on the filler cap is normal. When it gets really strong that's an indication of clogging CCV. There should be many threads on it. Check e46 wiki first.
