E34 (1989 - 1995)
Old 10-21-2012, 08:53 AM
tielkemeier tielkemeier is offline
Mein Auto: 1995 525i
Just bought e90 rims...
Will they fit my e34? I bought them off a buddy who just had a 2006 redone, and he told me they would fit, but I can't tell if I need spacers or not, or where I'd get them at. Any help??? Thanks guys!!
Old 10-21-2012, 09:00 AM
Banned
Mein Auto: car
I do believe that its considered a fashion faux pas to fit 3 series rims onto a 5 series, would generally attract dirty looks from those who know. In addition, the offset, hub sizes etc would likely be off, as even bmw seems to design it that way. I don't think they will fit without modifications. I suggest that you sell off your rims.
Having said that, detailed information on spacers, wheel hub measurements etc across all bmw classes can be found on google. Please cross reference whatever you're reading against other websites purporting to give you the same information, and ultimately, double check against the Bentley manual for E34s (please google for the download links).
I've heard that spacers may cause problems at high speeds unless they are very well made. It may be better to re-machine your wheel hub to fit these rims, if you insist on keeping them.
rgds,
Roberto
Old 10-21-2012, 10:03 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
They should fit but you will need spacers to get back to a ~20mm offset. H&R makes quality spacers that will not give you any trouble. The wheels offset should be stamped on the back side, you will probably need a 20-30mm spacer.
Go for it if you like the wheels. I am not sure how bobby figures the wheels from an e90 are a step down from the e34, but then, I'm not so sure about bobby on many levels.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 10-21-2012, 10:06 AM
supertech777's Avatar
supertech777 supertech777 is offline
+1
Sent from my Desire HD using Bimmer App
Old 10-21-2012, 01:09 PM
Josh429er Josh429er is offline
Mein Auto: 1989 BMW 535i
LOL. If they have tires on them then put them on get the jack stands posited so that the wheels are close to the gound on one side and slowly let the other side down to the ground and see what hits?
Snowsleds right. Nothin works on the rear of this car without a spacer it seems.
To roberto I had a rim with a cheap spacer and no hub centric ring on the back. I did 115 without any problem.
2003 GMC Sierra SLT 2500HD CC/SB
Old 10-21-2012, 01:17 PM
The Ornery Old Man
Mein Auto: GTI
Yeah, but did you do it like bobby, in third gear tach'ing her out for the "italian tune-up"? It sure would be cooler if you did
Old 10-21-2012, 02:35 PM
I was taching out 4th if that counts...I didn't read the part of the "italian tune up" where it says 5k in 3rd. lol
Old 10-21-2012, 04:12 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
i generally rev the guts out of it in neutral and slap it into drive, that seems to sort out any transmission errors.
on a serious note, E90 rims will fit, youll just need some spacers. same stud pattern/bore etc as e34, just wrong offset
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
rims tires wheels e34 e90
