E46 (1999 - 2006)
Old 10-21-2012, 08:41 AM
j_schroeder's Avatar
j_schroeder j_schroeder is offline
Mein Auto: 330ci
There is always something
I feel as if the list keeps compounding with this car. 2001 330ci
Current list:
1. Radiator has a very small pinhole on the plastic end so since the car has 130k on it I will be replacing he whole system.
2. Majority of the bushings in the rear cradle are shot and need to be replaced soon. Also the flex disc is dry rotten and cracked so that will be replaced as well as the carrier bearing.
3. CCV is leaking at some point causing a funky idle in colder temps and creating a small amount of suction at the oil cap.
Now I know the rad needs be done soon but what kinda priority should I be putting on these cause its just a lil irritating and pricey.
But on a brighter note the struts, cabs, rtabs, vanos, vcg, disa, p/s pump, tie rods, and control arms are new. So after its all done she will be almost brand new again lol
2001 330CI
Old 10-21-2012, 09:55 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Stop whining....it`s a BMW fer Chrissakes....
The road goes ever onward....
(R.I.P. Jever)
Old 10-21-2012, 10:24 AM
JJ3699's Avatar
JJ3699 JJ3699 is offline
Send a message via AIM to JJ3699
Mein Auto: 2003 325i
j_schroeder, I am in a similar boat. I recently replaced quite a few suspension components
Koni yellows shocks and struts, rogue Engineering RSM, M3 RTAB with Vorschlag limiters, and quite a bit more. Now there is a creaking noise when I turn my wheel, most of my window regulators are shot, and my sunroof is going to cost $2,000 to fix.
But then I remember exactly what FastBob posted... So we just need to suck it up then save up
.................BMW 4 LIFE.....................
Old 10-21-2012, 01:09 PM
Mein Auto: 330ci
I am glad that I can turn a wrench for sure making it drastically cheaper. But I just want to get opinions on how I should prioritize the next couple jobs.
2001 330CI
Old 10-21-2012, 01:13 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
Current list:
I know what you mean. I have two to maintain. MAF sensor yesterday on the 323I (P1188/P1189 codes) and today pulled the ICV on the 330 to clean it due to rough idle. They do have 212k and 149 k miles respectively so hard to complain too much and definitely beats car payments, most months
I see you did not mention rear dif bushing? oh sorry, but you need one of them too.
Old 10-21-2012, 04:45 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
You know better than that. You can replace the whole assembly for FAR less.
My ZHP is topping $3000 on maibtenance this year. But at 167k miles it still drives as new (better IMO)
Old 10-21-2012, 05:26 PM
Mein Auto: 330ci
I already have the bushing along with a flex joint and carrier bearing I'm just in the process of buying new subframe bushings and reinforcement plates.
2001 330CI
Old 10-21-2012, 06:29 PM
Mein Auto: 330ci
Double post
2001 330CI
Old 10-21-2012, 07:30 PM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
My rule of thumb is always this when a list of things comes up to fix and I can't do them all right away.
1. What keeps the wheels on and me safe. So suspension related things and brakes.
2. what keeps the car running, this includes engine and drive train. I go in order of what hinders them the most and what can cause more problems by not being fixed.
3. things that bug me. An intake boot crack would go in this category makes and annoying whistle but not usually that savaging to the engine(can be though.)
4. Cosmetics
Just some advice that you can do what you want with but if you cant tell your self when something on the car has been replaced I would replace them in the order I just listed. However it looks like you are doing a great job at keeping up maintenance from what you listed above.
Short suspension horror story.. My friend had a wheel hub going out in his 2001 cummins and ignored it for the better part of a year. lucky I wasn't with him when it went and he slammed off the road into the woods.
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 10-21-2012, 07:32 PM
4. Cosmetics
Old 10-22-2012, 12:02 AM
lgr122 lgr122 is offline
Mein Auto: '04 e46 Touring M-Sport
Well... after replacing all necessary pieces there might be some while to catch deep breath before beginning second round.
What i try to do with mine is always replace parts with good quality pieces so that wouldn't have to do same again very soon.
Oh and TannerT made fine list but ofcourse those can still go to subcategories...
Like for example risk of wheel falling off should be taken more seriously than something which only makes car handle bit funny,
but if you don't know the difference yourself then just take his list as it is.
Either way it's always good to fix what's broken, before it made next part to break also.
Old 10-22-2012, 07:34 AM
Mein Auto: 330ci
I have replace everything with oe quality or better, and I am glad I have and will continue to do so. It does make it a little easier knowing my suspension, driveline, and cooling system will be good for the next 100k or so.
I just changed my fuel filter while changing the oil yesterday and man what a difference. My idle picked up appx 100rpm or so and throttle response has improved. The drain pan that I emptied the filter into was black with 130k worth of deposits.
Has anyone had experience with the Stewart water pump? I'm leaning towards it die to he revised design and higher flow. Opinions?
2001 330CI
Old 10-22-2012, 07:30 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Thousands of things on an e46 that have to work right, and hundreds of items that need maintenance regularly.
And you've got to treat your wife nice every day!
Do both or everything falls apart.
