E34 (1989 - 1995)
coolant leak
finally found the coolant leak on my 95 525i. it seems to originate from the back of the block around the exhaust manifold headers. i will take some pics and post them after work(if im not too tired). anyone experience this?
1995 e34 525i M50 Auto K&N Sport Air Intake ![]() THE TACK TACK TACK IS GOOOOOOOOONE!!!!!!!!!!! It's Like a new car!!!!! |
I doubt its a block leak .I would be checking hoses that connect to the block under the intake manifold there is a small one that is prone to split,I think the one to warm the intake throttle body. Also a heater hose from block could leak.
Freeze plug?
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
freeze plug? those are below the exhaust headers right? aboot (im canadian) 2inches in diameter? its from above those.
Head gasket? Mine on leaks on cylinder 6.
2003 GMC Sierra SLT 2500HD CC/SB |
PLEAAAAAAASE NÒOOOOOOOOOOOOOOO.
![]() ![]() :b anghead:
Hi all.
I had a coolant leak from the hose connecting the block to the heater valve, on the block side. It's also around that area. Best regards |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
