Old 10-22-2012, 05:04 AM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z4 3.0, 535i
Error Memory From INPA For P0492
Well still trying to determine cause for my SES with OBDII code P0492. More and more it seems like I have the carbon build up in Bank 2.
Pump cycles fine, good airflow
No leaks in Y pipe
Valve appears to work
Pulled INPA memory
durchsatz zu gering - 2761 CDKSLS2 - Throughput low
Also
Korrekturfaktor Hohe gefreeztz B2(fho_u) - .84 - High correction factor ( Whats corrected?)
also see a mittelwert lambda of 1.01
Lambda-Sollwert of 1.00
does all this point to lack of airflow? or electrical problem with Bank2 O2? (I also assumed pre-cat exhaust O2 sensor on driver's side.
Old 10-22-2012, 02:25 PM
hooch999 hooch999 is offline
Mein Auto: 550i
Seems like O2 sensor.. hence low throughput.
I have seen INPA error code tables somewhere, try to google it
