The X5 SAV Forum
Old 10-22-2012, 03:54 PM
01-Beemer 01-Beemer is offline
Mein Auto: X5
Unhappy White Smoke
I have a '01 X5 4.4 that blows a large amount of white smoke at start up, then very little when driving. After idling (at stop) it will blow white smoke again. When it first started (couple of weeks ago) the temperature gauge reads normal and no noticeable change in power at acceleration or while driving.
Now the check engine light has come on and the codes are P1341, P1343, P1345 and P1349
Temperature gauge is still normal and a slight hesitation in power when accelerating.
The dealer is saying that it is either the crank case vent valve or the exhaust stem seals.
I have also heard that it may be something with the coolant.
Anyone else had or seen this problem?
Old 10-22-2012, 04:08 PM
sardor009 sardor009 is offline
Mein Auto: Bmw X5 4.8is
as i'm lil expirienced with Bimmers, all of them have problems with smoke. That would be your valve seals. Not just a valve cover gasket, but the valve seals. You have to reseal the valves and you'll be good. That job is big $$$ takes at least 8 hours. Good luck with that
Old 10-24-2012, 09:45 PM
mmorris_63 mmorris_63 is offline
Mein Auto: 4.4 x5
X5 smoke
I wish I could help but I'm getting to buy a 4.4 X5 with the same problem. I'm told that it may be the valve covers stopped up with soot from oil residue. Well I'm hoping so and hope that is your problem as well.
Old 10-24-2012, 09:54 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
2001 USA model should have the M62TU I think the N62 was late production. I will check CCV system ( vacuum place) deteriorated ccv hoses M62 dont have stem seals problems like n engines
Sent from my Nexus 7 using Bimmer App
Old 10-26-2012, 10:37 AM
Mudnyrey Mudnyrey is offline
Mein Auto: X5 3.0i
Sounds like a faulty OIL SEPARATOR UNIT!!
~Mud
Old 10-30-2012, 01:29 PM
88keys4u 88keys4u is offline
Mein Auto: 2006 BMW X5
Talking White Smoke
Are all the 2006 BMW X5's faulty with top end problems at 108K miles. Have white puffs at times when idles too long, then hard to start, but was told that oil cold have been changed to different type synthetic...recommends Castrol on engine at filler cap. Also, I am receiving this battery and voltage problem now and do not know what to do...think the alternator bad, only 108K on the car. Put new battery in and had to tow 60 miles because like many others, in the summer of 2012, the heat gauge was stuck because the X5 did not recognize the new battery...so another $105.00 at dealer for "diagnostic" as they said to program the battery.....been teaching electronics for 25 years, still looking for one of those "programmable 12V Auto Batteries". Worked fine for about 2 months and then all of a sudden, daughter in car with my grand kids and the car fails, trans light on, and ABS and other 4X4 indicators. Jump car, runs well for less than one week, and first cold snap being this weekend, all goes haywire which indicated bad battery. On way to work this morning and have brown out and shut down of electrical system, tow for $75.00 and charge battery at my school and now trying to determine the problem. Is is the alternator or the voltage regulator. This car has gremlins and electronic demons and is beginning to resemble the misery of Range Rover owners. My 1996, 328i is great car as is my 1974 VW Bus....dependable.....if before 1999!!! Maybe prince had a point with song "1999"! Work at a school with brand new $10k scan tool system, getting now waveforms from the Alternator or Voltage Regulator indicating past problem or not on top of it yet............I need help!!!!!!!!!!!!!
Old 10-30-2012, 01:57 PM
Mein Auto: X5 3.0i
So have you checked the alternator with a VDM at the battery terminals in the engine bay? If so, what was your output reading? A regulator issue can be noticeable at the connection. I had an intermittent problem on a car that showed the alternator was good, even under a tested load, even though I took it to two different places? but in fact I new the battery was new, and that the alternator voltage reading said other wise and an intermittent problem, so I changed it. No issues.
Have you checked all possible connection.. Battery and other else where? Damaged the ECU from jump start?
The white smoke maybe an Oil Separator issue. White smoke is a common problem if the unit is failing. I use the BMW synthetic, or Mobile one. Either way, each Qt. is about the same price.
~Mud
Old 10-30-2012, 07:42 PM
I feel like it is and intermittent FM problem also, put in new battery in July, and then had to take to dealer for update of program to match battery. First cold snap of winter indicates battery, but on way to work dash lit up and basically browned out ...slow discharge as if alternator not working. Are the voltage regulators or alternators water cooled? Makes sense with load these cars are under. When I got to the technical center and charged battery, was not getting proper duty cycle on scope at alternator, but had another checking an may not have been making necessary measurements. Will get started again tomorrow in early am. Great cars, but BMW is making a mistake with technology instead of refining their outstanding products, they are attempting to add technology that is costly and almost unnecessary. My 1996 328i is a jewel with 138k and i love it. Previously owned 1984 735i, rear-ended and totaled but saved my daughters life!! Obviously have had to replace hoses, water pump, radiator and necessary evils of a 16 year old vehicle, but an amazing car. Stills rides tight, performs great like all the older inline 6 cars, and smells like a BMW eery time you open the door. That car and my 1974 VW Bus most dependable cars I own. Wish the X5 was this well designed!!! Thanks.
Old 10-30-2012, 07:44 PM
DMM Voltage was 13.5-14.2 and on the analog near same, but had slight deflection on idle.
Old 10-30-2012, 08:31 PM
CNY3 CNY3 is offline
Mein Auto: X5
2003 x5 3.0 with this problem.
Crankcase ventilator froze and white smoke is exhaust. In my case it routed back into the cabin ventilation system.
Fried both catalytic converters. Vehicle cabin stank of fumes for weeks.
Quoted $8800 fix.
BMW advised me that I should not drive my vehicle on short trip when temperature is below 0.
I live in Canada.
As you might imagine I was quite taken aback by this response.
I worked my way up through the chain at BMW Canada, was told that the crankcase ventilator was not part of the power train so was not covered.
I was once threatened by BMW Canada that they would now charge me the entire amount if I did not stop my inquires. I even had a BMW representative in Canada tell me "He was BMW and to stop."
I was able to get BMW Canada to assume responsibility of both catalytic converters and reduced fix to $2300 CAN.
I had had vehicle serviced as per manufacturers guidelines.
BMW installed "covers" to protect the crankcase ventilators.
I inquired if there were checked as part of routine maintainance; No.
I inquired if the crankcase ventilators were heated electrically or pneumatically; No.
I rebutted that this is a design flaw for a vehicle built to be driven in Canada where it is below 0'C 1/2 the year.
I pursued this though Transport Canada Passenger Vehicle Division and was advised that this was/is a known problem to BMW, for example, the issued a Tech Safety Bulletin about this particular issue; however, no recall and dealers and BMW is not legally obliged to inform you of this short coming. Apparently simply issuing the TSA covers them.
There is still an ongoing investigation within Transport as the Inspector that contacted me informed me there were major issues in Minnesota, Alberta, Ontario and North Dakota.
Old 10-31-2012, 07:05 PM
Mein Auto: X5 3.0i
I take it this reading was without the engine running? 13.5 VDC seems a little low and I would question that a bit. Should be an internal regulator to the alternator.
~Mud
Old 10-31-2012, 07:07 PM
Mein Auto: X5 3.0i
Quoted $8800 fix.
I live in Canada.
Isn't the cold climate optional? I know there are things that are required for such cold climates by BMW Technical Bulletins.
~Mud
Old 11-01-2012, 06:42 AM
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: 01 525i, 01 X5, 91 Z32TT
^It's an insulation blanket wrap around the Oil Separator Unit. Find a longer route with hway to burn off oil deposit.
01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT
Old 11-03-2012, 09:08 AM
naved naved is offline
Mein Auto: X5
How do I prevent this from happening
Live in Northern Alberta where the weather can go as low as -45C
My X5 hydrolocked last year and cost me a lot to have it towed to Edmonton to get fixed
Any suggestions on preventing this from happening?
Old 11-03-2012, 10:18 AM
Mein Auto: X5 3.0i
Lots of talk about this issue.
Not sure what year or model you have, but with the last 7 of your vin could look up teh cold climate kit from BMW.
http://wiki.bavariantechnic.com/inde...eparator_Issue
http://www.xoutpost.com/bmw-sav-foru...e-version.html
~Mud
Old 11-03-2012, 11:26 AM
Mein Auto: X5
Thanks Mud!
It's a 2001 x5 3.0 ..thanks for the threads..going to be a while till I can replace oil sep' and hoses..
Q: What can I do until then
Q: Is it safer to idle the engine till it warms or drive till warms up..?
Old 11-03-2012, 11:36 PM
Mein Auto: X5 3.0i
Follow the users manual says;
Driving off immediately:
Do not allow the engine to warm up by Leaving it run while the vehicle remains stationary. Instead, begin driving at moderate engine speed. This is the fastest way for the cold engine to reach it,s pirating temperature.
I start mine and let it idle for about 20-30 sec to allow oil pressure to build (which takes far less time) and the engine components to be fully coated and then just keep it under 3k rpm and driving easy. Letting it sit idling may allow your engine to warm up, but it does not warm up the transmission.
~Mud
Old 11-04-2012, 10:20 AM
04X54.4i 04X54.4i is offline
Mein Auto: 2004 X5 4.4i
Isn't there a recall on the PCV/CCV system? I read it in my buddies datanet for my 04, should have the recall sticker in the engine compartment....I don't see it, and mine is starting that smokey smoke at idle.
Old 11-06-2012, 08:37 AM
White Smoke and Oil Plug problems
DO YOU HAVE A LIST OF RECALLS ON THIS CAR....I feel like there should be a recall on the total vehicle. I had my oil changed at Tom Williams BMW of Birmingham and wanted to change the oil my self and no I cannot even get the oil plug out without fear of rounding out the torx head.....so there goes another $150.00...byt the way put in an alternator and 2 PVC oil pressure valves and so far the white smoke is gone. The original ones were totally rotted at the seams and destroyed allowing changes in oil pressure. Please let me know if you have experienced the sabotage from dealer techs as I feel I am getting.
