E34 (1989 - 1995)
Old 10-24-2012, 09:25 PM
Josh429er Josh429er is offline
Mein Auto: 1989 BMW 535i
Now you said earlier that you have an original set as well as the replicas. Have you checked both?
2003 GMC Sierra SLT 2500HD CC/SB
Old 10-24-2012, 09:26 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Maybe check the under contact surface, or inside of the hub. What are they replicas of? Maybe we can find the specs of the authentication...
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 10-24-2012, 10:02 PM
Ssuss34 Ssuss34 is offline
http://i1341.photobucket.
Mein Auto: '89 E34 535i
Yes I do have originals in storage. No I have not checked them
Cos it's a bitch to get to them.
They are replica throwing stars. But do you reckon they would be exact as the originals down to offset?
Old 10-24-2012, 10:03 PM
Does every set of rims ever made have an offset number on them?
Old 10-24-2012, 10:33 PM
Originally Posted by Ssuss37 View Post
ok, so I have taken one of my wheels off and looked everywhere. There were no stapmings of anything with ET... Keep in mind these are replica rims. Whats another way of finding the offset?
However I did find the following (See Pics, not sure if it means anything to you)
Also my tire sizes are:
Rear: 235/45ZR17 94Y
Front: 235/45ZR17 97W
Let me know if any of this helps.
Ok, heres a post from someone on Bimmerforums who looks to have the same replicas as I do. He reckons the offset is ET15
http://forums.bimmerforums.com/forum....php?t=1831631
And here is another post with the same wheels saying the offset is +18
http://www.driftworks.com/forum/whee...18-offset.html
So can you do your calculation based on worst case scanerio and let me know?
Old 10-25-2012, 01:04 AM
Now before you said that you had original rims, as well as the replicas, if there identical then did you check the originals for markings too?
Old 10-25-2012, 07:42 AM
Monsignor's Avatar
Mein Auto: Sig
ok i will be going on the assumption that they are 17X8 et18 (3mm wont make a much of a difference) and that you want agressive fitment with a stock ride height car?
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 10-25-2012, 05:37 PM
17x8 et18 with an agressive fitment. The vehicle has been lowered 55mm in the front and 30mm in the rear (from stock ride height)
Old 10-25-2012, 08:53 PM
Banned
Mein Auto: car
Old 10-27-2012, 05:49 PM
Bump - 95E34 you worked it out fore yet?
Old 10-30-2012, 11:30 AM
Monsignor's Avatar
Mein Auto: Sig
apologies. I got hit with sandy.
Big green girl makes a great storage tank for generator fuel lol...
20-25mm Rear
5-10mm Front
Would put your fitment close to mine.
my REAR fitment is currently from the hub:
117.3mm of wheel inside
111.3mm of wheel towards the fender.
Your REAR fitment right now given the assumptions:
119.6mm of wheel inside
83.6mm of wheel towards the fender
You are 27.7mm further in your wheel well than I am. I'd go 20-25 so you avoid rubbing (I rub)
Please make sure than you get properly extended lugs with the right thread pitch to use. You should be able to get 5-7 full turns or so into the hub.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 10-30-2012, 07:16 PM
20-25mm Rear
5-10mm Front
I hope the bimmer was safe and tucked away in bed.
Thanks for the calcs. To be safe, do you reckon I should choose a spacer 5mm less than your calcs or safe to go with what you have worked on based on my assumptions on offsets?
Old 10-31-2012, 06:33 AM
Monsignor's Avatar
Mein Auto: Sig
E34 and 350z were in the garage. E28 weathered the storm, and successfully i should say also!!
Um, thats really your call. If it is a 13mm offset, youll get tons of poke and it probably wont even fit.
I love stanced euros so i'd do everything in my power to get proper fitment, which means checking the OEM ones not matter how far tucked away they are. 5mm is nothing really but if they are the 18mm and you do go 5mm less than we're talking 10mm difference from my calcs which would be noticable...
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 11-06-2012, 05:50 AM
Monsignor's Avatar
Mein Auto: Sig
please update us on which sizes you get and your results.
Also, pictures or ban
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 11-06-2012, 02:32 PM
Will be sure to post up pics, on hold for the moment as I just forked out for new pirellis and lower control arm rear bushes to be fitted.
