E36 (1991 - 1999)
Old 10-22-2012, 09:08 PM
johnmack johnmack is offline
Mein Auto: e36
M3 swap into a non vanos
I have a 92 non vanos car an just picked up a 99 m3 drivetrain minus ecu an harness can anyone give me some help on how to make this swap work. Thanks!
Sent from my PG86100 using Bimmer App
Old 10-22-2012, 11:02 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
You will need an ECU and harness for your drivetrain.
1998 BMW 328is
1966 Pontiac GTO
Old 10-22-2012, 11:15 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Most likely one from M50tu (Vanos)
-Dino
Old 11-04-2012, 06:25 PM
Mein Auto: e36
I've heard that I can use an obd1 vanos harness and ecu has anybody done this?
Old 11-04-2012, 06:54 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Yep tons of people. Google S52 OBD1 conversion. You will need a vanos harness and probably a red label dme.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 11-04-2012, 07:15 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Yep, you'll need to buy these.
Use your M50's intake manifold, along with the rest of the intake system (except injectors). Use the exhaust from the S52.
You can use either valve cover, but you'll need to make an adapter for the crankcase vent if you use the S52 one.
Also, you'll need an S52 chip for your red label DME. You can get one from the big companies, such as Turner, or you can talk to an independent tuner.
-CJ
Old 11-04-2012, 07:56 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
where in jersey are you?? i have red label dme, 413 (iirc)
and like these guys already said, a harness would be necessary.
be preppared for a bit of work.
df
