flashing oil light and lumpy revs - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 10-23-2012, 02:52 AM
Sexy Celina Sexy Celina is offline
Mein Auto: bmw 316es compact e46
Exclamation flashing oil light and lumpy revs
Hi Guys. Please help a damsel in distress!!
I recently used steal seal and white shepherd leak seal on my bmw 316es compact as was advised by a friend. The symptoms were lumpy revs occasionally, misfire in cylinder 3, wet in cylinder 3, white smoke on start up that disappeared after 10 mins. i used the steel seal and leak seal and it was great for a whole day. This morning i started it and no power, i put my foot down and it stalled. If i turned the engine off then on but with my foot full on, it revs high and falls to 700 then fluctuated between 700 - 1200rpm. I can also hear a intermittent gurgling noise inside the cab from behind the dash which goes when i turn the heating off. Any ideas would be greatly appreciated
Old 10-23-2012, 07:14 AM
Stiglitz Stiglitz is offline
Shake Hands with Beef
Mein Auto: 2001 BMW 325i
Blown head gasket and most likely warped the head by now is what it sounds like. White smoke is never good, check the oil, if it looks like chocolate milk coolant got into the oil and the car is a paper weight.
Old 10-23-2012, 10:35 AM
Hi. Thanks for reply. There's no cream cheeses etc in the oil. It's very strange. It isn't overheating either. I did hear a high pitch squeal like a slipping belt or something. Any thoughts?
Old 10-23-2012, 11:20 AM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & ST 335i
You probably have a check engine light on. Get the codes and post them here for us.
p.s. Bars leak is the best head gasket temp sealer. Never even heard of the other stuff you mentioned.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
flashing oil light, gurgling noise, leak seal, lumpy revs, steel seal
