E46 (1999 - 2006)
Old 10-23-2012, 08:41 AM
glarior glarior is offline
Mein Auto: 328ci
2000ci wheel bearings/ABS ring
Not sure if my terminology is correct for the ABS ring around the wheel bearing.
I was replacing the control arms, CAB and wheel bearings on the front... I noticed my new wheel bearings ABS ring (what the sensor reads) has 50 troughs while the old bearing w/ABS ring had 42. I know that will cause a problem with the ABS if one or two wheels are reading a different pulses.
Has anyone ordered wheel bearings from OEM bimmer parts and had the correct ring for ABS at 42 troughs? They have F.A.G. OEM and SKS.
Any other suggestions I can do? Thought about moving one ring to the other but I am hesitant knowing my luck....
