Old 10-23-2012, 01:34 PM
cuorealfa1 cuorealfa1 is offline
Mein Auto: 5er GT 535d
F07 open big hatch with interieur hatch button on the floor panel
Hello
ello888 was asking some time ago for the correct coding for F07 to set the interieur hatch button to open and close the big hatch.
http://www.bimmerfest.com/forums/sho...640219&page=52
if found the correct coding settings so that the functionality would be:
hatch button floor panel: open and closes the BIG hatch
fob button 3: opens the small hatch (long press)
fob button 4: opens and closes the BIG hatch (long press)
CAS -- 3002 CLM -- REMOTE_KEY_SPECIAL_FCT -- aktiv/Werte=01
CAS -- 3002 CLM -- REAR_SCREEN_IS_PRIMARY -- aktiv/Werte=01
CAS -- 3002 CLM -- OPEN_RSCR_WITH_REMOTE_KEY_SPFN -- nicht_aktiv/Werte=00
CAS -- 3002 CLM -- OPEN_RSCR_WITH_PUBU_A_PILLAR - aktiv/Werte=01 change to "nicht_aktiv/Werte=00"
HKL or HKFM -- 3010_HKLBEDIENUNG -- SCH_FBD -- aktiv/Werte=01
HKL or HKFM -- 3010_HKLBEDIENUNG -- SCH_TOEHKI -- nicht_aktiv/Werte=00 change to "aktiv/Werte=01"
HKL or HKFM -- 3010_HKLBEDIENUNG -- TASTER_FBD --nicht_aktiv/Werte=00
HKL or HKFM -- 3010_HKLBEDIENUNG -- USE_FBD4 -- aktiv/Werte=01
cheers
2010 BMW 535d GT
Old 10-24-2012, 02:24 AM
ello888 ello888 is offline
Mein Auto: BMW
Wow, thanks!
I think I got used to the 3rd and 4th button on the remote switched by now.
But having this is good and I might set it back correctly.
