E36 (1991 - 1999)
Old 05-10-2016, 10:12 AM
domvni domvni is offline
Mein Auto:
Driveshaft???
Okay so my driveshaft came out in the middle of the highway the other day because the guibo bolts weren't installed correctly. I have replacement bolts but I have no idea how to put the drive shaft back in. Click image for larger version
ID:	562686Click image for larger version
As you can see a couple bolts are still in there ( have to take them out, ) but my driveshaft isn't close enough to put the bolts back in
Old 05-10-2016, 05:23 PM
mark21742's Avatar
mark21742 mark21742 is offline
Mein Auto: 94 325is
You should be able to pull the back of the driveshaft back to meet up with the joint.
I worked at a shop that specialized in BMWs and you should have seen the look on people's faces when i would tell them they needed a new "guibo" joint.....like i said muffler bearings or turn signal fluid lol
Old 05-10-2016, 05:48 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Just say "driveshaft flex disc" and it won't sound like a made up word....
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 05-11-2016, 12:08 PM
Mein Auto:
I'll try it out, hopefully it works
Old 05-12-2016, 09:49 PM
Mein Auto:
Didn't work. & it turns out I need a new center bearing ):
