E36 (1991 - 1999)
Old 10-23-2012, 06:45 PM
Thee_Antic Thee_Antic is offline
Mein Auto: 1995 M3
Cool Rod knock/piston slap...coming from the clutch?
Cars in neutral. Idling. Randomly starts making very minor piston slap/rod knock noise.
I cry, pray to Chesty, then push the clutch in to take off from the light cause idgaf. As soon as I push the clutch in, bam, no more noise. I let it out..noise.
Wtf? Never heard a ****ing clutch make these types of noises....
Old 10-23-2012, 06:47 PM
Mein Auto: 1995 M3
Oh ****. I think I got that backwards..
Fml do I actually have to build my bottom end -_-
Old 10-23-2012, 06:57 PM
Mein Auto: 1995 M3
If it helps, when I push the clutch in and give it a slight rev, no noise from the bottom end. Also, when I hear this sound in neutral and rev it high, engine purs like a sexy kitten.
The trans has been feeling very notchy, and overall drives like ****. Might be running the original fluid. What I think I'm hearing is something in the tranny? I mean, even in neutral the engine is still spinning the tranny. I put the clutch in, rotating mass in tranny stops, therefor sound stops. Right??
Old 10-23-2012, 09:50 PM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
You might have a lightweight flyhweel which exhibits "chatter" at idle speed. Its not a cause for concern unless the issue appeared out of nowhere.
Changing your transmission fluid would be a good first step.
Old 10-23-2012, 10:07 PM
Hellawut??
Mein Auto: who knows?
thee antic....
how big are your rims? and what style front lights do you have?
-Franklyn
Old 10-24-2012, 04:47 AM
Mein Auto: 1995 M3
Just talked to the PO, stock flywheel. Sachs clutch.
Just bought the car.
Stock headlights, clear corners, 18 or 19" ASA rims. I'll check tonight.
Old 10-24-2012, 05:05 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
one item to check is the starter as well. in my 318 the starter wouldn't retract all the way causing the noise you describe. Replacing that solved my problem.
As for the clutch chatter, my current 328 only does that when engaged and moving with very low revs. Say in reverse up a hill where RPM's are less than 900...
If you are having clutch chatter, then that would mean your clutch is not disengaging all the way.
I would also check for a CEL. Make sure it works (key on, engine off, all lights should come on for a moment).
If you can, post a video/sound clip of the noise.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 10-24-2012, 05:31 AM
Mein Auto: 1995 M3
I will get on that tonight, so you don't think it's the bottom end then?
Old 10-24-2012, 05:34 AM
still learnin'
I don't know, it very well could be. its better to check and research first before tearing apart and throwing money away
99 540i TiAg
Old 10-24-2012, 08:21 AM
jayjaya29's Avatar
Come at ///M3
Mein Auto: 97 M3
I highly doubt its the lower end. If it goes, it would make noises so horrible it would be undriveable.
Old 10-24-2012, 09:44 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
is it possible someone machined the flywheel?
I think i read somewhere you arent supposed to do that on our cars
-Dino
Old 10-24-2012, 09:50 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
After YEARS of believing the same thing was finally clarified to me. Most shops & machinists aren't capable of it, but resurfacing dual mass flywheels IS possible.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 10-27-2012, 10:48 PM
HakenTT's Avatar
HakenTT HakenTT is offline
Mein Auto: '91 E30
transmission low on oil or worn out mainshaft bearing. Top it off with 30w non detergent oil, noise should go away.
Old 10-28-2012, 05:05 AM
Mein Auto: 1995 M3
Turned out it was indeed low/bad trans fluid. Switched it out and voila, no more noise.
Old 10-28-2012, 09:02 AM
hornhospital's Avatar
D'oh, You Kids!
I assume you used lubricant appropriate to the gearbox.
(FYI, 30w non-detergent isn't)
Quotes to live by:
Old 10-28-2012, 01:24 PM
HakenTT's Avatar
Mein Auto: '91 E30
You did not even say "thanks", next time don't be stupid and check the obvious fluid levels before wasting everybodies time here.
Old 10-28-2012, 05:30 PM
Mein Auto: 1995 M3
Are you ****ing kidding me?
Old 10-28-2012, 05:35 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
^Well that was odd... Maybe now would be a good time to pull those panties from your crack? In reality, we should be angry with you for recommending that someone put 30W oil in their transmission...
1998 BMW 328is
1966 Pontiac GTO
Old 10-31-2012, 07:36 PM
Mein Auto: 1995 M3
Hmm. Had some quality seat time with the car today, and noticed that the sound did indeed come back. I parked her, got on my back with my trusty stethoscope and listened away. Sound is gear noise from the trans..definitely. Engine sounds normal. Can hear the crank and rods, pretty smooth. The trans however, sounds like this:
Regardless..I"m just going to swap it out anyways. It definitely shifts better with the new fluid, no more grinds or notchiness.
Old 10-31-2012, 08:03 PM
HakenTT's Avatar
Mein Auto: '91 E30
Once the tranny is run low on ATF oil for long time, then few bearings inside may wear out and make noise. This is why I said to top it off with non detergent 30W oil, it will delute just fine with ATF and will ticken the viscosity just enough to quiet down the bearings. At least I saved you from engine rebuilding
No, ZeGerman we should all be angry at you for not recommending anything.
Old 10-31-2012, 08:10 PM
Victell Victell is offline
Victell
Mein Auto: E30/E36
Sounds like the transmission input shaft bearing. Common on e30s, not sure about e36s. If it is the input shaft bearing then it wont cause damage or fall apart, just be annoying. Changing fluid usually doesnt help.
Old 10-31-2012, 08:11 PM
Mein Auto: 1995 M3
A) There was the proper amount of fluid in the trans when I changed it out, it was never low, just old. Clearly the thing has been used and abused, case closed.
B)Detergent anything, no.
C)Don't talk **** to Mr.German. If he has no knowledge on the subject I would much rather him not butt in with detrimental advice, like telling me to put 30w detergent oil in my trans.
B)Kindly, gtfo.
Old 10-31-2012, 08:14 PM
Mein Auto: 1995 M3
I thought about this..didn't think the noise would be this..bad?
Irregardless. Its getting switched out sooner than later, so no worrys
(They should arrive in the mail tmrw)
Old 10-31-2012, 08:15 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
i wanna know how adding non detergent w30 to a trans saved him from rebuilding his engine...
df
Old 10-31-2012, 09:41 PM
ZeGerman's Avatar
Warm Leatherette
That guy is nothing but a troublemaker. One look at his youtube videos and his posts on other auto forums pretty much confirms his status as a jerk.
1998 BMW 328is
1966 Pontiac GTO
