BMW Coding and Programming
Discuss coding options and features on your BMW here. |
"Flapper" Valve in my exhaust
I'm not sure which models have them and which don't, but, I do know that my 550IX has a "flapper" valve in one of the exhaust outlets. Anyone know exactly how it works and whether or not it can be coded?
p.s. Thanks to all of you guys that have helped me to get to the point where I am able to "code" my car. |
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
If it's like my old 330 its vacuum actuated, if you want to keep it open you just remove the hose and plug it
Since nothing is simple anymore, I figured that BMW used vacuum for the energy to open the valve, but, still utilized a electrically controlled solenoid valve to control when it opens. Oh well, I'll give it a go and let you know.
It is a butterfly valve. It cannot be coded as it runs off the vacuum pump. Search the golf tee method for plugging the vaccum hose. Some people have also just used a large nail through the butterfly valve to hold it continuously open. It sounds much more aggressive.
In my F21 M135i ist is not vacuum controlled it is electrical, pulling the cable forces it to stay open. Found something in DME-Module will try to edit it
Regards
Best regards, Don M ![]() 2013 550i, BMW F800ST, ML350 |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
