Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 09-07-2012, 09:56 AM
fhowie2002 fhowie2002 is offline
Mein Auto: 1985bmwm6
m6
i have a 1985 m6 european model. it wont start but if i spray starter fluid in it it will run all day .what is the problem with my car
Old 09-07-2012, 12:35 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Fuel pump working? (can you hear it when the key is on?)
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 09-07-2012, 02:55 PM
the car will run until you shut it off then it wont start unless you spray it with starter fluid
Old 09-08-2012, 06:16 PM
Limarxy Limarxy is offline
Mein Auto: 1999 BMW 540i
could be a cold injector valve. replace it or hot wire the external butron for it.
Old 09-09-2012, 12:03 PM
i have replaced the cold start valve and the blue temp sensor , where is the external button for the cold valve.i also noticed the fuel pump
Old 10-26-2012, 03:57 PM
ericono ericono is offline
Mein Auto: 1985 M635, 2000 528iT
Be careful, there are 2 fuel pumps back there. One internal to the tank which works as a supply pump to the external fuel pump by the tank. If either one of those doesn't work then the engine may not get fuel. Also, make sure your fuel pump(s) relay is working. Those can sometimes fail on you.
Can you give us a run down of what you have tried so far? It will help us to understand so that we can help you.
Thanks,
Eric
Old 10-26-2012, 06:23 PM
it was the crank sensor
