E30 (1982 - 1993)
Old 10-24-2012, 02:56 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
Intermittent Dying?
So.. I went on a cruise with the Ohio Bimmers forum. It was pretty intense to say the least. My little E30 had some trouble keeping up with all the M3's, M5's, and the M1's, but I did very well on corners to keep up. After the first leg of the cruise, my car started acting up.
1985 325e 2.7 torque monster (lol)
It runs fine while driving, but every now and again I'll pull up to a light or stop sign and my car will randomally die. Sometimes it'll back its idle down to 450-500 but not die, then the next light it'll just die. Within the past year I've replaced: fuel pumps, oxygen sensor, spark plugs, fuel filter, spark wires, engine coolant temp sensor, timing belt, distributor, rotor, valve cover gasket, almost all vacuum lines, and alternator. There's more but this is all I could remember from the fuel and emissions system. It never did this before, but now it does. Anybody know where to start on this?
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 10-24-2012, 04:05 PM
hornhospital's Avatar
D'oh, You Kids!
Idle control valve. Test it. You either have a vacuum leak or that valve is not working. A vacuum gauge would tell you a lot.
Sent from my MB860 using Bimmer App
Quotes to live by:
Old 10-24-2012, 07:19 PM
BMWFatherFigure's Avatar
Old School
+1 on above. It seems you've replaced everything else.
Current:
E38 Parts Car
Previous:
Old 10-25-2012, 07:58 AM
Newman271's Avatar
That Guy
Cool, I have 3 Iacv's I bought from a salvage yard for 2 bucks a peice I'll try swapping it out. I did unplug that Iacv and it idled up.. I do kinda hear a little sucking sound around the Iacv vacuum line. Also, I found out last night I need to clean my throttle body, getting off the highway my throttle body butterfly got stuck at 2500rpm I had to smack it with a wrench to get it to return to normal. So, I'll clean the throttle body and try another Iacv and check for leaks in the Iacv hose. I'll keep you updated.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 10-25-2012, 08:05 AM
Gustavoerod's Avatar
Gustavoerod Gustavoerod is offline
Mein Auto: 2006 530i
Crankshaft sensor!!
Old 10-25-2012, 08:08 AM
Newman271's Avatar
That Guy
I have two in the transmission that on a Oscilliscope seem to be reading fine. I checked them when I replaced my transmission and clutch, about a year ago.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 10-26-2012, 02:27 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
How on earth does a throttle butterfly get stuck so hard, that you need Guerilla tactics to free it ?
Unless of course it twisted in the housing because the scres locating it on its shaft came loose...
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 10-26-2012, 07:14 AM
Newman271's Avatar
That Guy
I took off the throttle body last night and it was pretty gummy and nasty. I scrubbed it with 3M throttle plate cleaner. Lubed up the linkages and cable, took it for a spin. After a 3 hour cruise, there is no problem now. I do believe it is fixed. Thanks for the assistance guys
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
