Old 10-24-2012, 11:46 PM
ktnamja ktnamja is offline
Mein Auto: 2001 BMW 525i
Smile ~ suspension ~
Hello all,
I would like to lower my 2001 525i since everything is stock about the car. Lowering it might give it an aggressive look. I'd like to keep my stock rims & tires on, as well. Not really in the market to buy huge rims & tires.
So, what would all of the suspension experts recommend for a lowering set-up? I've looked at E-bay for lowering suspension and this is what I've found:
link #1
link #2
Does anyone have any experience with these 2 coil-over(s)? Any suggestions?
Old 10-25-2012, 05:27 AM
Fudman's Avatar
Fudman Fudman is offline
You don't say what your current suspension is or what size wheels you are currently running. If your primary reason for doing this is to improve appearance and you wish to retain your current wheels/tires, adjustable coilovers is the best approach as the height would be adjustable. However, overall appearance is a function of several considerations, including height, rake, size of wheels and how well your wheels/tires fill your wheel wells. If there is a specific "look" your are seeking, it is better to replicate those components to attain that "look". Otherwise, you are experimenting and that can lead to disappointment.
Old 10-25-2012, 05:50 AM
King 5's Avatar
King 5 King 5 is offline
Send a message via AIM to King 5
Mein Auto: 1997 BMW 528i
Bilstein sport struts with H&R sport lowering springs. Check out my review,
http://www.bimmerfest.com/forums/showthread.php?t=592304
1997 BMW 528ia 2/97
2004 BMW 330ci 4/03
2008 BMW 335i 3/08
Old 10-26-2012, 11:20 AM
Thank you for answering, Fuldman & King5. My current suspension is stock. My wheels & tires are stock, too. Which is 225/55/16 and BBS BMW stock wheels. The reason I would like to retain my stock wheels & tires is because I feel the car would be more responsive to its current stock mode. Meaning, stock wheels & tires would work well with the car than aftermarket big rims & tires.
If I were to choose bigger rims & tires that would mean longer stopping distance, needing bigger brakes, and costly tires. I just wanted to lower the car about 2-2.5" that it is now, so it would look like it has stance. Are the coil-over(s) in the links I've listed any good? Thank you.
Old 11-13-2012, 09:15 PM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
I'd be weary about purchasing ebay brand coilovers. I'd recommend that you check out the BMW E39 ST V1 coilovers by KW Suspension if you're looking to keep cost down yet want something that is quality for your BMW.
The ST V1 will give you the ability to adjust the height of your car with pre-set damping from the engineers at KW. This is perfect for an ever day driver and does still maintain a ride quality that is similar to the OEM Sport Suspension. Itís slightly stiffer and will definitely give you more responsiveness on turns as compared to the OEM setup!
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm
Check out the Blog for daily updates!
coilovers, lower, suspension
