E36 (1991 - 1999)
Old 01-17-2013, 08:38 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Originally Posted by hnaz View Post
Don't worry. From what I read about making a non-VANOS car to VANOS, it is a huge pain. But if you're patient, you'll be fine.
And I like how the project is coming along! Good on you!
He's swapping the whole motor so there's nothing to it. All he needs to do is source a Vanos engine harness. Converting to OBDI is a little tricky, but there are write-ups that explain it in detail.
If you want to see how to convert an engine to OBDI without the use of the expensive coolant pipe adapters and knock sensor adapters, look at my 3.2L swap thread.
-CJ
Old 01-17-2013, 08:42 AM
jkmeisl's Avatar
jkmeisl jkmeisl is online now
Josh
Mein Auto: Built inze Fatherland 325
i have seen your thread! Very helpful!
M3GT sedan - my slow progress thread ->http://www.bimmerfest.com/forums/sho...040&highlight=
Old 01-17-2013, 09:13 AM
cj.surr's Avatar
some kid
Cool. Hopefully it wasn't to hard to weed through. Was only a progress thread, really.
-CJ
Old 01-17-2013, 04:51 PM
jkmeisl's Avatar
Josh
kinda got side tracked and polished the roof. looks awesome though
ID:	358116   Click image for larger version
ID:	358117   Click image for larger version
Old 01-17-2013, 05:03 PM
cj.surr's Avatar
some kid
You polished different color paint into it?
-CJ
Old 01-17-2013, 05:37 PM
jkmeisl's Avatar
Josh
No haha just a pic with flash and a picture wothout flash
Sent from my SGH-T989D using Bimmer App
Old 01-17-2013, 05:38 PM
cj.surr's Avatar
some kid
Haha I know. Looks much better though!
-CJ
Old 01-17-2013, 09:43 PM
jkmeisl's Avatar
Josh
Haha thanks dude! Just got a limited slip differential Tonight. Its a 3.91 but ill just swap the lsd into my 2.93 so happy
Old 01-18-2013, 07:46 AM
jkmeisl's Avatar
Josh
I've heard the e36 sedan with no sunroof is considered rare? is there some truth to this?
Old 01-18-2013, 09:07 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
I dunno, but I do know a 1995 M3 with Sunroof delete is pretty rare. There was a guy in my area selling a non-sunroof M3 for 5 grand. Kinda wish I jumped on it.
Old 01-18-2013, 03:52 PM
jkmeisl's Avatar
Josh
i dunno guys...
Old 01-18-2013, 03:55 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Looks better than the stuff that came out of Chad's E36 sedan.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 01-18-2013, 04:37 PM
hornhospital's Avatar
D'oh, You Kids!
i dunno guys...
Kaopectate would stop that.
Quotes to live by:
Old 01-18-2013, 04:41 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
And yeah. I'd say your HG is shot.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
jkmeisl's Avatar
Josh
hahaha awe... gross
Old 01-18-2013, 04:42 PM
jkmeisl's Avatar
Josh
ya I'd say the same. M52 it is
Old 01-22-2013, 12:55 PM
jkmeisl's Avatar
Josh
ordered the head gasket set for the m50. and pick up an limited slip diff and a Xbrace.
any one ever swap the lsd into an open diff before?
also anyone ever installed an xbrace before?
thanks in advance
Old 01-22-2013, 01:23 PM
hnaz's Avatar
BMW CCA Member
thanks in advance
Yes! I have done this and it is fairly simple. Here is the instructions I used (and it worked great, just don't use red loctite at the start. Thread the bolt in first until the well bolt is secured, then use the red loctite):
http://www.pelicanparts.com/bmw/tech...66-X-Brace.htm
Good luck! It was fairly easy to install. And the difference in steering versus just the plain old rod is amazing. Much more responsive too.
Old 01-22-2013, 06:38 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
thanks in advance
Diff swaps are very easy. Just gotta label all of your bolts and put them back in the order they were removed. The other consideration is 4-bolt versus 6-bolt output flanges. You'll have to see what your car has, and compare it to the diff you're installing. Even if they're different, you can swap out the output flanges on diffs very easily (or so I've been told).
I installed an x-brace a number of months back. Very easy job. I highly recommend using the AVK threaded nut inserts rather than the OEM BMW nutserts. The AVK inserts are nicer because they have ridged collars which helps prevent spinning while crushing them down and while tightening the bolts during x-brace installation. They're also flatter when fully crushed down, which means that you don't have to bother counter-sinking them like you should do with the OEM nutserts. Otherwise, the process is very straightforward. Just drill your holes, hit the holes with some rust inhibitor and paint, insert & crush the threaded inserts, and install the x-brace with Grade 8 or higher hardware (using thread lock).
Also, you don't need to buy or rent a nutsert tool to crush the nutserts down. Just make one-time-use "tools" by combining a hex bolt, some nuts, and washers, like so:
1998 BMW 328is
1966 Pontiac GTO
Old 01-22-2013, 07:51 PM
cj.surr's Avatar
some kid
Yeah, diff swaps are very easy... Unless the axle flange bolts are rusted on. And 90% of the time they are. At least around here.
-CJ
Old 01-22-2013, 09:08 PM
D'oh, You Kids!
He's not simply swapping diffs, he's swapping an LSD mechanism into an open diff. That's a whole 'nother ballgame. It's not easy and it's not usually considered to be a DIY project.
Quotes to live by:
Old 01-22-2013, 10:53 PM
jkmeisl's Avatar
Josh
Does anyone have any info on this?
Old 01-22-2013, 11:21 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Send a pm to both Frank (Mr Gutsa) and df (drivinfaster). They've both gone into this topic in detail in the past.
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-22-2013, 11:22 PM
ZeGerman's Avatar
Warm Leatherette
Oh, definitely don't waste your time trying to swap an LSD into an open diff case. It can be done, but the tolerances are so small and vital that it's definitely not the kind of thing you want to learn on (unless you don't care how long it lasts).
1998 BMW 328is
1966 Pontiac GTO
Old 01-23-2013, 10:19 PM
jkmeisl's Avatar
Josh
Awe thats to bad. I was hoping for a DIY. Where should i take it to get swaped in?? A transmission shop?
