Performance
CAIs, SCs, differentials, SSKs, exhausts etc..... |
I can clean your fuel injectors. Just pay for shipping and the fluid
I'm thinking about offering a service for the guys/girls on some forums i enjoy. It's *Free Injector Cleaning and Testing. I've been working for Bosch than Volvo and BMW in Europe, but my love for those cars is pretty much gone and I've been a Mercedes Enthusiast for a while. I remember the difference a clean injector makes in the way the car runs and how often i used to see them in poor condition. In case you have a faulty injector, i have a bunch of spare ones (Mercedes and BMW cars of late 80s to late 90s) i kept through the years and could sell those at half the market price for used units. This is WHY: R3VLimited Forums - View Single Post - I can clean your fuel injectors. Just pay for shipping and the fluid Here's How I bring them back to life 1. Initial Visual Inspection - Check the injectors for signs of physical damage. 2. External Degrease Soak - Soak them in a degreaser solution 3.External cleaning - Brush off the loosened grime from the injectors 4: De-filtering - Remove the old filters in preparation for ultrasonic cleaning. 5. Ultrasonic cleaning - The Injectors are soaked in Degreaser and Left pulsating in the Ultrasound Bath 6. Purge the injectors - Install the injectors on the Fuel rail and spray into a container to ensure none of the fluid we use in the ultrasonic cleaner gets put into the calibration fluid. 7. Initial flow - Flow through the machine checking for spray pattern and any signs of malfunction. 8. Filter Basket installation - Install the new filter basket. 9. Reassemble - Using all new applicable parts (O-rings, spacers, pintle caps) I'm in Southern California by the way. About 1 hour from LA I can do 2 kits a day or 3-4 on a weekend. So the turnaround should be 24-48 hours So for a kit of 8 I spend 25$ + shipping about 6$ I use Odorless Degreaser @ 17$/gallon Repair Kit @ 1$/Injector. USPS Flat rate priority mail 6.10$ I'm not doing this as a business, i just like working on cars in my spare time. (But of course will take donations) You can include a set of filters and o-rings with the package if you have a specific brand you like. And I won't charge you the 1 $/Injector If you care to see how specific injectors were performing, you need to mark each of them with the Cylinder number and i will make sure i keep those numbers for your record. Please note you forum nickname on the package to help me keep track of communication This is a nice article on how to remove your injectors with pictures. Applicable for the E36 engines but process is similar on most of the cars Pelican Technical Article: BMW 3-Series E36 Injector Replacement Here's the process similar to what I do. (i have nothing to do with the company advertised in the video or the original uploader of that video) Last edited by MEPEH; 12-15-2012 at 10:06 PM. |
IN STOCK (will update the list as I sort them) In stock injectors will be sold at 10 $/piece. Cleaned and tested. With 12 months - unlimited mileage BMW 0 280 150 415 - Rated at 156 cc/min @3bar - 15.9 ohm 0 280 150 715 - Rated at 155 cc/min @3bar - 15.9 ohm 0 280 150 440 - Rated at 200 cc/min @3bar - 14.5 ohm 0 280 150 778 - Rated at 200 cc/min @3bar - 14.5 ohm 0 280 150 779 - Rated at 200 cc/min @3bar - 15.9 ohm 0 280 150 211 - Rated at 155 cc/min @3bar - 16.2 ohm 0 280 150 129 - Rated at 196 cc/min @3bar - 2.3 ohm 0 280 150 552 - Rated at 156 cc/min @3bar - 15.9 ohm 0 280 150 714 - Rated at 200 cc/min @3bar - 15.9 ohm 0 280 150 126 - Rated at 196 cc/min @3bar - 2.3 ohm Mercedes Benz 0 280 155 203- Rated at 206 cc/min @3bar - 14.25 ohm 0 280 155 207 0 280 155 209 - Rated at 206 cc/min @3bar - 14.25 ohm 0 280 155 217 - Rated at 206 cc/min @3bar - 14.25 ohm Other Lucas D3761FA - 318IC Lucas D3763FA/1747406 - M60 M62 V8 Enines Lucas D3165KA - JAGUAR XJR SUPERCHARGED Bosch 078 133 55IN - Audi Siemens 000 078 8323 - Mercedes M119 V8 =============================== I will buy your older injector @ 3 $/piece. If you buy the reconditioned ones from me Last edited by MEPEH; 11-20-2012 at 08:29 AM. |
You can find more activity and reviews about this service on r3vlimited forum
http://www.r3vlimited.com/board/showthread.php?t=266477 |
injector
So for a 2003 530I it would cost me how much for the job I have a set of injectors. Let me know
5$ per injector to service yours or 10$ to replace. (not sure if i have yours in stock though)
I am interested in a set for the s52 motor maybe the 24lb if I can use them with a reflash or just a replacement of the 21lb. Can you email me how to do this and what your suggestions would be. I'm putting a m50 manifold and bored out throttle body on and a possible bigger maf if I need to with the 24lb injectors. If you can help that would be great. I'm rebuilding a M3 after a bad PPI and so I want to do it right and get the mist out of the motor before boosting it. Thank you. My email is Bshriver29@gmail.com.
Sent from my HTC PH39100 using Bimmer App |
Sorry for the super late reply. Just found my notification
I don't have any in stock but you can send your for servicing. Now speaking of pounds ... that's too complicated. I assume it's 220cc/min and you want to upgrade to 250cc/min Don't have any in stock either. I know the m5 uses the 260cc/min and that would work for your application if you intend to boost the engine. At least I can confirm that the upgrade does make sense for you application and is in fact recommended. If you decide to upgrade, just check a big supplier, they normally have the tables with flowrates and you can pick up the part number for your use. Stay with the same manufacturer and you'll be good |
Do you have injectors for a 2000 E38 M62TU? Here's the Bosch part # 0280155823. Thanks.
BMW '00 740il w/196,xxx miles (his), DIY timing guides complete! M60 Manifold, BDC Throttle Body, Muffler delete BMW '02 530iA w/140,xxx miles (hers) BMW '09 R1200GS Adventure w/13,6XX Smiles
Anyone have MEPEH's contact info? I got one PM from him but he didn't give me any contact info.
PM sent on the other forum. Sorry about the delays
I have about 10k views on my threads related to injector service and it's getting harder to keep track of communication on different forums, so I decided to add a web page for those interested in reaching out to me.
http://mepeh.com/ You can use the form on the Contact Us page and i'll get the message instantly on my phone. Very convenient to keep track of the orders. I added a facebook page as well and will be able to communicate easier through it. https://www.facebook.com/MEPEHinjectors Not sure what i'm going to do with these, but i'm trying to migrate my other projects to my websites and hope this will be easier for you as well. May be i'll add a check out page to help out those without a paypal account |
I got 8 30lb Bosh (I believe) yellow bigger injectors I had on my E39 540i. Im sure they're dirty cause It threw a code after 5 months. I will need new O-rings for them too. give me total price and I'll send them to you. I'm in Cali as well.
Thanks I'll PM you the address |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
