Old 12-12-2012, 06:51 AM
PapaRocco PapaRocco is offline
Mein Auto: 2013 x3 35i
Auto-Stop not working 2013 X3 35i
Just noticed my Auto Stop stopped working and of course, the button on the dash is not set to off. Anyone have any suggestions?
Old 12-12-2012, 11:06 AM
Tangsta Tangsta is offline
Mein Auto: Alpine White F25 35i
What's the temperature outside?
Auto Start-Stop won't activate below 3 degrees celsius (about 37 fahrenheit)
Old 12-12-2012, 11:18 AM
Thanks. It's been cold. I'll see if it works when it gets warmer. Should it work around 40 or higher?
Old 12-12-2012, 12:06 PM
rambos rambos is offline
Mein Auto: X3
Not true. I know this is in the specs. This morning it was 28F and Start/Stop was functional in mine.
I believe, the 37F limit is for the INSIDE TEMPERATURE not the outside. My car was pulled out of the garage which is usually 10 degrees higher than the outside temp. Just the guess but there could be also another criteria that not published.
lbjgh's Avatar
lbjgh lbjgh is offline
Mein Auto: 2013 X3 M-Sport
Low temps and battery load... did you have the seat heaters on, blower fan, heated steering wheel, lights, etc. ?
Old 12-12-2012, 12:19 PM
Maybe your ambient temperature sensor hadn't cooled down yet. When I pull out of heated underground parking into -10 degree weather, the 3 degree temperature warning doesn't chime for 3-6 blocks.
In either case, OP, it could be any one of 20+ things that stops it from turning on.
There's a list here
Old 12-13-2012, 02:34 PM
Vortec4800 Vortec4800 is offline
Mein Auto: 13 X3 35i MSport, 09 135i
If you go to the EffecientDynamics screen and come to a stop it will tell you why it didn't stop. Climate, battery, driver selection, etc. Could give you an idea.
