The X5 SAV Forum
Old 10-26-2012, 12:27 PM
Andrew Hillman Andrew Hillman is offline
Mein Auto: X5 30i
x5 petrol torque convertor
does the torque convertor use a bearing on the 3.0i petrol auto box G M type box as this
could be the source of the noise I mentioned in an earlier post although I am not sure
whether the torque convertor spins when in park or neutral,as the noise that concerns me
only occurs when the gearbox is in gear,it sounds like a slack chain.thanks in advance for any help given andy
Old 10-27-2012, 05:54 AM
TechWrench TechWrench is offline
Mein Auto: '99 540i, '02 X5 3.0i
The transmission torque converter is turning when ever the engine is turning. It is bolted directly to a flex plate, which is directly bolted to the engine crank shaft.
Old 10-27-2012, 10:03 AM
Mein Auto: X5 30i
lack of transmission oil
would anyone think that lack of transmission oil is the cause of a noise in the auto
transmission as the noise is only heard in gear at rest, or idle.
many thanks for the earlier reply.
