E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
1987 325ic. fuel draining ?
can i drain the fuel from the line coming from the tank into the filter? meaning if i pull the line there will that drain the tank?
as always, thanks! |
Yes, all the fuel in the line will come out but not the whole tank full of gas. Under 8oz. will come out. It is under some pressure so point it away from you.
![]() Last edited by Tkaczuk; 10-27-2012 at 09:46 AM. |
are you trying to drain the tank or just trying to replace the filter?
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
Depending on the various heights you might start a siphon and will empty the tank, just not fast.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
there's a allen type screw on rear passanger side of tank, undo it and tilt car from front driver side.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
