Old 10-27-2012, 11:08 AM
Ionic202 Ionic202 is offline
Mein Auto: 2013 535i xDrive
2013 F10 Coding
Was finally able to get back into this and made a quick list for the coding that I have done. The only one not working at the moment is the video playing while driving. There must be another code that I need to locate yet to enable the video while moving. While I am at this, we should all give a big thank you to shawnsheridan for his work on this.
DL
HUD Turnsignal Indicator
Code KOMBI / HUD_PIA_BLINKER = aktiv
Code KOMBI / BLINKER_HUD_ENABLE = aktiv
Code HU_NBT / HUD_TURNSIGNAL = aktiv
The iDrive check box will not show up, but it works.
High Beam Foglight
Code FRM / 3050 / NSW_AUS_BEI_FL / nicht_aktiv / Werte=00
Change to nicht_aktiv to enable Fog Lights with High Beams / Flashers
Auto Start/Stop
Code CAS / 3000 TC / TC_MSA_MEMORY /aktiv / Werte-01
Sets car's Auto Start/Stop function to start in the last used setting (e.g. Off) when the engine is started.
DVD Video Enable
Code HU_NBT 3000 HMI / SPEEDLOCK_X_KMH_MAX / value = FF
Disable DVD Speedlock - Part 2
Code HU_NBT 3000 HMI / SPEEDLOCK_X_KMH_MIN / value = FF
Disable DVD Speedlock - Part 1
Code HU_NBT 3000 HMI / VIDEO_NUR_MIT_HANDBREMSE / nicht_aktiv / Werte=00
Video just in combination with handbrake. Use w/ above SPEEDLOCK_X_KMH_MIN and SPEEDLOCK_X_KMH_MAX.
TPMS Temperature/Psi Display
Code HU_CIC 3001 / EXBOX RDC_SAFETY / aktiv / Werte=01
Adds Pressure and Temperature Readings to the TPMS Screen.
2013 535i xDrive, Imperial Blue Metallic, Oyster and Black Nappa Leather, ZCW, ZDA, ZDH, ZLS, ZMP, ZPP, ZTP, 2TB, 323, 416, 4CE, 4U1, 5AC, 677, JB4 Tuner
Old 10-27-2012, 12:17 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
DL
DVD Video Enable
For VIM, make sure you only changed the Werte Values to FF, and did not also change the DropDown paramaters above them.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 10-27-2012, 02:28 PM
mdernst's Avatar
mdernst mdernst is offline
Mein Auto: 2013 M5
Also, on my 2013 F10, it seems that the parameter VIDEO_NUR_MIT_HANDBREMSE was replaced with VIDEO_HANDBRAKE - but the setting changes were the same.
Current: 2013 M5
Previous: 2012 A7; 2011 S5; 2011 X5M; 2010 750Li; 2009 M3 Sedan; 2008 X5; 2003 M5; 1998 540i 6 spd.
Old 10-27-2012, 06:19 PM
DVD Video Enable
I forgot that I could not set value = FF for either of these codes. I had to leave it inaktiv or aktiv with a limit. How do you set the value = FF for this? I'm sure that is why this is not working.
DL
Old 10-27-2012, 06:32 PM
All new 2013's with the HU_NBT instead of HU_CIC will be VIDEO_HANDBRAKE.
- BMWCCA #446923
- flick
Old 10-27-2012, 06:33 PM
DVD Video Enable
DL
Read this:
https://www.rapidshare.com/files/348...e%20Values.pdf
- BMWCCA #446923
- flick
Old 10-29-2012, 09:26 AM
jdco jdco is offline
Mein Auto: 650I
Anyone have luck w/ closing the trunk and windows via key fob? I've tried using the values on the cheat sheet but it doesn't seem to be working. Maybe I'm not pressing the right button?
Everything else I've tried is.. HUD turn signals, entertainment and TPMS info.
Old 10-29-2012, 02:09 PM
Mein Auto: 650I
Not sure what went wrong the first time, but I just tried it again and now can open and close the trunk from the interior button and remote.
Does anyone have the seatbelt gong codes avail?
Old 10-29-2012, 03:45 PM
The Trunk coding does not immediately take. The car needs to go to sleep and wake back up before it starts working.
Get the Seatbelt stuff from ACSM Module on the Cheat Sheet:
http://www.bimmerfest.com/forums/att...9&d=1339114795
- BMWCCA #446923
- flick
Old 10-29-2012, 07:20 PM
Mein Auto: 650I
Thanks Shawn. Waiting was the key.. Unfortunately it looks like the codes have changed since this cheat sheet was made. SBR_BF_GWF_BF and SBR_FA_GWF_FA do not exist.. do you or anyone happen to know what they were changed to?
Here's a screenshot of the options avail:
Old 10-29-2012, 08:04 PM
You are in 3001.
Look in 3000 Ausstattungsflags for these:
Gurtzustandsanzeige_Beifahrer_GWF_GZA_BF
Gurtzustandsanzeige_Fahrer_GWF_GZA_FA
Initialwarnung_GWF_IW
SBR_BF_GWF_SBR_BF
SBR_FA_GWF_SBR_FA
SPW_BF
SPW_FA
- BMWCCA #446923
- flick
Old 10-29-2012, 08:39 PM
Mein Auto: 650I
You are in 3001.
SBR_BF_GWF_SBR_BF
SBR_FA_GWF_SBR_FA
SPW_BF
SPW_FA
they're not in 3000 Ausstattungsflags.. but found these and setting them to nicht_aktiv disables the seatbelt gong.
Old 10-29-2012, 08:51 PM
Yes, that is them.
What section is that in?
The two expanded ones are the equivalent of these:
SBR_BF_GWF_SBR_BF
SBR_FA_GWF_SBR_FA
I can also see the others:
And the Prewarning ones at the bottom are the equivalent of these:
SPW_BF
SPW_FA
So, that is all 7 of them.
- BMWCCA #446923
- flick
Old 10-29-2012, 09:31 PM
Mein Auto: 650I
Yes, that is them.
SBR_BF_GWF_SBR_BF
SBR_FA_GWF_SBR_FA
SPW_BF
SPW_FA
I meant SBR_BF_GWF_SBR_BF and SBR_FA_GWF_SBR_FA were not in there.. Sorry I didn't specify. Thanks for your help
Old 10-30-2012, 12:33 AM
wdimagineer's Avatar
wdimagineer wdimagineer is offline
Mein Auto: 2013 M5
Funny timing. I just did this on my M5 tonight. Couldn't find some of the original values so made some educated guesses that panned out. Glad to see this worked for someone else.
2013 ///M5
Alpine White · Sakhir Orange Full Merino
Executive · Driver Assistance · B&O · 20" HRE P40SC · Akrapovic Evolution · H&R Springs · Many Euro Mods
Old 10-30-2012, 06:02 PM
Mein Auto: 650I
Does anyonee know if the following renamed on 2013 F10?
CMB_MEDIA and FEM-Body
Old 10-30-2012, 06:20 PM
F10 never had FEM_BODY. Combox is now built into the Head Unit so CMB_MEDIA is now part of HU_NBT.
- BMWCCA #446923
- flick
Old 10-30-2012, 07:27 PM
Mein Auto: 650I
Thanks Shawn.
Looks like they changed quite a bit. I'm trying to find the codes to have ringtones play from my phone and to change the turn signals to flash 5x instead of 3.
Old 10-30-2012, 07:44 PM
PittX52011 PittX52011 is offline
Mein Auto: 2011 X5, 2013 550 xi
I am new to F10, want to get some coding done on MY 13 F10, I am in southeast, whom should I contact. (Atlanta / Knoxville, TN area).
Thanks for the help. I am clueless in this regard.
Old 10-30-2012, 08:50 PM
Thanks Shawn.
I don't know know on the 5x Flash, but did you try HU_NBT / 3003 TELEFON_TELEMATIK_ONLINE / INBAND_RINGING = aktiv for the phone ringtone?
- BMWCCA #446923
- flick
Old 10-30-2012, 08:57 PM
I would open a new post requesting coding help in Atlanta / Knoxville, TN area.
- BMWCCA #446923
- flick
Old 10-31-2012, 07:37 AM
Mein Auto: 650I
That did it.. Thanks!
Old 10-31-2012, 02:09 PM
Mein Auto: 2013 M5
Does anybody on this thread have automatic high beams on their 2013? Just wanting to get some values to compare to my 2013 M5. My car did not come with it but I've since enabled it and also ordered the appropriate steering wheel stalk buttons. Before I fully complete the retrofit I want to make sure the coding is accurate.
2013 ///M5
Old 10-31-2012, 02:29 PM
Mein Auto: 650I
Unfortunately mine didn't come with that feature.. I'd like to enable it though if you want to share the codes
Old 10-31-2012, 04:59 PM
Read this thread:
Coding High Beam Assistant:
http://www.bimmerfest.com/forums/sho...ight=high+beam
- BMWCCA #446923
- flick
