Old 10-27-2012, 12:39 PM
val3ntin3s's Avatar
val3ntin3s val3ntin3s is offline
Mein Auto: 2007 E92 335i ED SP
CAS read coding data error
I get a "File for cafd_00000000f-005_024_222 file not found! (C012)" when i try to edit it. I've looked around this forum for someone with the same error but only found people get this when they try to access the HU_CIC.
I also tried replacing the SWE files in my C:\ESysData\SWE that didn't help. I'm using pzdata 47.5 and I've set my EST to C:\ESysData\e-sys est\Code Away.est
any help is appreciated. thanks in advance!
2012 F10 535i | Alpine White | ZPP | ZSP | Tech | Lip Spoiler
Sold - 2007 E92 335i | Spark. Graph. | ZSP | 6 speed MT | Lip Spoiler
Old 10-27-2012, 01:38 PM
Kasdar Kasdar is offline
Mein Auto: F10 520d
PM sent
Old 10-27-2012, 09:23 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
cafd_0000000f.caf.005_024_222 was one of 6 that were in 47.1 and orphaned in the 47.4 PSdZData release.
I assume you have it now.
You do not need any files in C:\ESysData\SWE. This folder can be empty.
The SWE files in the PSdZData folder here C:\ESysData\psdzdata\swe is all that is needed.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 10-27-2012, 09:25 PM
val3ntin3s's Avatar
Yea kasdar sent me the link to download the file, have had a chance to do it yet. I should be good after installing it, thanks for everyone's help!
Old 10-28-2012, 12:10 PM
val3ntin3s's Avatar
Tried it today and everything went well thanks again guys!
Old 01-05-2013, 07:01 PM
Jblackbelt Jblackbelt is offline
Mein Auto: BMW 750Li
Not to drag up an old thread but I am getting the same thing, just a different file number. any help is much appreciated
File for cafd_00000000f-005_024_231 file not found!
Using 48.1
www.jblackbelt.com
Old 01-05-2013, 07:14 PM
Using 48.1
This is for your F01/F02 CAS Module I presume, and sadly you won't find it.
It is one of two known "oddball" CAFD's that made it onto a few cars when 2.46.3 and 47.1 was current, but never made it into any PSdZData release.
These two CAFD's essentially do not exist:
cafd_000000f9.caf.007_002_157
cafd_0000000f.caf.005_024_231
Your car needs to be dealer programmed with the latest ISTA/P or your CAS module flashed with newer firmware.
- BMWCCA #446923
- flick
Old 01-05-2013, 07:15 PM
Thanks Shawn!
www.jblackbelt.com
