E34 (1989 - 1995)
Subframe Noise
Under sudden acceleration from a standstill I hear and feel a clunk in the rear end. My first and only guess so far is the subframe mounts. I'm getting these replaced soon, I just want to make sure that's what's causing the clunk.
Do you feel the clunk when you decelerate quickly from speed ? If you do, then its the rear differential, that has developed too much free play.
Your best bet is to inspect it.
Thanks for your posts guys, I am starting to believe it is the diff. I'm getting the gear oil changed on the 7th of November and during that time I'm going to try and replace all worn driveline pieces. I'll update this thread when I'm doing the work. (hopefully with photos)
Could be slip joint on drive shaft?
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
I have no idea yet, just gathering ideas. It's to the point where it starting to annoy me a lot when I'm accelerating from a stop
It may be subframe mounts http://www.bmwe34.net/E34main/Mainte...ameBushing.htm
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
