Old 10-27-2012, 09:35 PM
Dmurry101 Dmurry101 is offline
Mein Auto: 2004 745LI
Brake change...light not resting
I change my brake pad and I have tried two different sensors and I can't get the light to rest...I have also tried going into the car settings and rest it there....still did not rest.....I have a 2004 745LI
Do anyone have any idea what should I try next?
Sent from my EVO using Bimmer App
Old 10-27-2012, 09:38 PM
I have a 2004 745LI
Old 10-28-2012, 03:41 AM
inspi inspi is offline
Mein Auto: 03 BMW 745i, 06 BMW 750Li
You need to reset your service interval thru hidden menu in KOMBI
INSPI
Old 10-28-2012, 08:39 AM
dommm dommm is offline
Mein Auto: 2008/750i
I also changed my rear brake pads & tried to reset the service interval thru the hidden menu but the red car warning light will not turn off & now when going to the I-Drive menu it says my rear pads are -16,000 over due. Just before I got the pads changed the I-Drive menu said -8000 over due.
When I did the reset in the hidden menu the last step highlighted reset & when I pushed the button it can up OK or something like that. I also reset the engine oil interval & it reset it to 24,000 kilometers. I scrolled through the I-Drive to see if there was any other service that was due but everything was green other then the rear breaks which is staying red along with the red car warning light.
Any suggestion's on how to solve this problem would be appreciated.
Old 10-28-2012, 08:53 AM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: '03 745Li
When you changed the pads, was their damage to the pad wear sensor?
HID Guide
LED Guide
Old 10-28-2012, 09:02 AM
my mechanic said he did not think there was any damage to the wear sensor.
Old 10-28-2012, 10:09 AM
1bad540's Avatar
1bad540 1bad540 is offline
you need a new sensor.
[SIGPIC]
99 540i sport, acs type 2's chrome, acs spler pdls,Euroclrs
04 745i aw sport,21's aib's acspedals& rf splr(sold)
00 328i Prem Aw18" 335spt whls(sold)
02 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav
05 X5 3.0, pana rf,nav,xenon,cldweather, premium.ipod hookup, 20"4.6rims staggered 315rrs.
06 750I aw, sport. chrome21's,acs pdls,acs rfsplr,mtecs,8k hid fogs,Leds.oem ipod&sirius
03 VIPER, forgelinewheels,tune,exhaust,intake.
Old 10-28-2012, 05:09 PM
I will order & replace the sensor & will give update once I have installed it. Where would be the best place to order it? Thanks
Old 10-28-2012, 05:17 PM
1bad540's Avatar
ebay.
[SIGPIC]
Old 10-28-2012, 05:25 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Certified 7
Mein Auto: 2004 745i
$10 on eBay or try fcpeuro.com
Old 10-28-2012, 06:25 PM
WOW you & 1bad540 are right on. I just found it on ebay for $11.50 & free shipping. My dealer quoted me $54.
Old 10-28-2012, 07:22 PM
wjjklj's Avatar
Certified 7
You have 2 sensors on your car. 1 on the left (drivers side) front and one on the right rear. You can change these easily enough by jacking up the car on the jack pad and remove just the wheel that you are replacing the sensor on. No need to remove the caliper, pads, or rotors.
Old 10-28-2012, 10:34 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 745LI/ F02
Autozone $20.00
Old 10-29-2012, 04:36 AM
Yep. With bad sensor you'r not able to reset service interval. Just measure resistace to check the sensor-continuity test or temporary bridge the sensor to see, if you can reset interval
INSPI
Old 11-16-2012, 06:45 PM
Update
OK, the sensor arrived yesterday & I installed it today & reset the rear brake service interval setting & the red light turned off & the interval now shows 31 tmls.
I noticed when scrolling through the service interval list that the front brake interval reads 43 tmls & I reset it a few months ago.
Why would the front interval read 43 tmls & the rear interval read 31 tmls when I just reset the rear today but reset the front sensor months ago?
Old 11-17-2012, 06:29 AM
CBS interval should be 32000 miles for rear and 25000 miles for front brake pads
INSPI
Old 11-17-2012, 07:01 AM
That makes sense to me. I wonder why my CBS interval for the front pads is reading 43,000 mls? Not only is 43,000 much higher then the maximum number, I reset the front CBC months ago. I also checked in the I-Drive menu & it also reads 43,000 for the front?
While the rear is not so far off, it should be reading 32,000 not 31,000 since I changed it yesterday & have not driven the car?
ID:	349834   Click image for larger version
Old 11-17-2012, 08:20 AM
If You have diagnostic software, then You can correct it
INSPI
Old 11-17-2012, 08:45 AM
I do have INPA software installed on a laptop but have not used it for anything yet. Is that the software that would be needed for this & would you be able to lead me through the process of correcting this problem? I would be most grateful.
Old 11-18-2012, 12:30 AM
Hi, I know You can use INPA to reset service interval(under Body-Instrument cluster), but I don't know if You can correct data with INPA-never tried. I always used DIS software. In DIS You go to: Diagnosis - Function Selection - Service Functions - Maintenance - CBS Correction, Vehicle Data and change the value
INSPI
