Old 10-28-2012, 01:35 PM
Espen Lysholm Espen Lysholm is offline
Mein Auto: 2012 BMW X3 2.0DA
Water under sound insulation/carpet 04 X3
Hi,
I have read and searched this forum and other forums hoping to find an answer.
My 04 BMW X3 2,5IA is soaked in water under the sound insulation (under the carpet). I have no sunroof, and the carpet is not wet.
I have checked the rubber seals, the drainage in doors, in the engine room etc, etc.
Itīs pure (old) water smell so there are no washer fluid leak.
I am now drying the interior, but I have to find where the water is coming from.
Please help
Kind regards
Espen Lysholm
Old 10-28-2012, 01:38 PM
x3brian x3brian is offline
Mein Auto: X3
Check the cabin air filter housing if you haven't already. Leaves in there have also been known to cause water leaks.
Old 10-28-2012, 02:38 PM
I have cleaned out the drains and looked into the filter box. It was ok.
Kind regards
Espen Lysholm
Old 10-28-2012, 03:06 PM
bmwbob89 bmwbob89 is offline
Mein Auto: 2004 X-3 740i 325xi 88M5
One of the vapor barriers under the door panels is most likely the culprit. Wait till it rains and you will see it leaking in. Common issue and you just need to pull the door panel and apply new bead sealant to the barrier. Have any the door been worked on in the past? If so that is probably the one leaking. You can also have someone spray the car with a hose and look for the leak.
Old 10-28-2012, 03:08 PM
By the way a couple of big electric fans blowing into the car will dry it out pretty fast. I've done that many times at the dealership. Overnight should get most of it dried out.
Old 10-29-2012, 02:50 AM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
my money is on a vapro barrier, I need to replace one of mine soon also.
Old 10-29-2012, 03:54 AM
I have ordered new vapor barriers to day. I think the problem is the back door, but have ordered for both doors. The car is now dry after many hours with electric fan. I have also cleaned the carpet and sound insulation with my Foma Mimo.
Kind regards
Espen Lysholm
Old 10-29-2012, 12:44 PM
You normally don't need new barriers only the sealant that holds them to the door. The new barriers don't even come with the sealant. You can get it at the auto parts store its made by 3M.
http://www.amazon.com/3M-08612-Windo...rds=3m+sealant
Old 10-30-2012, 10:59 AM
chewchewone chewchewone is offline
Mein Auto: X3
+1 and what others are saying... vapor barrier... just go to the dealer parts section and ask for the butyl tape, get enough to go around your doors and replace all existing one... in my case, i just added the new stuff to the old one. good luck
Old 11-03-2012, 12:53 PM
After drying the insulation last weekend, I have gotten new vapor barrier and bought a black silicon/glue seal. To day I checked for new leak after a week with various weather. As I assumed, a new leak was found. The insulation in the rear footwell was wet, but the front footwell was still dry. Ergo the leak is most likely coming from the rear passenger door
The car is now drying once again. Tomorrow new vapor barriers will be mounted with fresh new seal. Lets hope that this will fix the problem.
Kind regards
Espen Lysholm
Old 11-05-2012, 03:21 AM
To challange you a little bit more:
If the problem isn't the vapor barriers? What could be the cause of the water leak?
As the only one in Norway right now, I am waiting for it to rain :-)
Kind regards
Espen Lysholm
Old 11-05-2012, 08:02 AM
That is usually the leak. I would go no further until you confirm it. Make it rain yourself with a hose.
Old 11-05-2012, 09:05 AM
With temperature below zero itīs a little bit problematic to "make rain" :-)
Kind regards
Espen Lysholm
Old 11-05-2012, 04:37 PM
Sorry I did not know it was that cold there already. You have to wait until it warms up a bit or find a garage.
Old 11-21-2012, 01:00 PM
Hi,
I can confirm that the leak is stopped. Thank you for your tips. The problem was the vapor barriers.
Kind regards
Espen Lysholm
