Old 10-29-2012, 04:23 PM
putitupmike putitupmike is offline
Mein Auto: 2001 525i wagon
2001 528i. running lean
Error code says that both front banks are running lean. What is the first thing I should do?
Old 10-29-2012, 05:14 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
Vacuum leak.
second is vacuum leak.
And the third thing to check is...you've already know.
Old 10-29-2012, 06:00 PM
MikesE39's Avatar
MikesE39 MikesE39 is offline
Mein Auto: 03 530i Loaded
2001 528i?? does that exist?
Old 10-29-2012, 06:12 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Fourth thing is vacuum leak ...
Fifth is vacuum leak ...
And, sixth ... is ... umm ... look here.
- How to diagnose a BMW E39 engine misfire (1)
Old 10-29-2012, 10:09 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
There's no "both front". If just one bank then maybe not vac leak. If both then still maybe not vac, could be maf needs crc cleaner. Also check fuel trims real time, see if lean at say 3k rpm, if so then maybe not vac but fuel flow.
Old 10-30-2012, 06:50 AM
Follow up. Sounds like my 525i... has a vacuum leak. At least that's where I will start. I hope cleaning it will be good enough as they are $250, and frankly I would rather just pay my kids rent. Mike, regarding your cars look, I think the red rims look great and especially when seen from the rear and you get some taillight in the photo. Anyway I will Google cleaning a MAF and get to work on it. Wish me luck, cuz lean or not... it''s just purring.
Old 12-08-2012, 03:12 AM
delorian delorian is offline
Mein Auto: Bmw 528 98
Hi.
Any progress on this im about to replace my MAF but can't find any part number printed on it.
I dont think i have an airleak because i hear no noise when i take the oilcap of on idling or when i remove the dipstick.
Whats strange is that there is no difference in idle when disconnecting the MAF.
I will order a new one as soon as i can find a part number printed on it, its not printed on the top.
Mine looks like this but nothing is printed on it.
http://www.maf-shop.com/en/vdo-sieme...766a940685f8ae
Where do i find the partnumber on my MAF?
Old 12-08-2012, 06:15 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
^RealOEM.com
Sound like you need a new MAF if it makes no different when it's disconnected.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 12-09-2012, 06:21 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
Follow up. Sounds like my 525i... has a vacuum leak. At least that's where I will start. I hope cleaning it will be good enough as they are $250, and frankly I would rather just pay my kids rent. M Anyway I will Google cleaning a MAF and get to work on it. Wish me luck, cuz lean or not... it''s just purring.
if you suspect that you have an air leak, how does cleaning the MAF seal off the leak?
aren't u better off looking for a leak, like in between the accordion folds of the intake boot, per se?
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 12-09-2012, 08:25 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Too cut to the short and sweet--check out the following--if you can DIY you can have ago and spot the area's that can cause your problems
http://www.bimmerfest.com/forums/sho...eaks+revisited
