Old 12-07-2012, 05:04 PM
NordicWolf NordicWolf is offline
Mein Auto: Mercedes, BMW
110K on a Manual 03' 530i - what to look for?
Hi-
In my search for a 2003 530i in Topaz Blue/Gray w/ a Manual I have come across a 03' 530i Manual with Sport/Premium with 109,500 miles - Blue water metallic/Gray Int. - a nice combo too
It's located 5 hours form me I'm in LA this is up north near San Francisco. Trying to decide if its worth the trip to see in person.
This is silly but for some reason I have a lot of hesitation with a car at 110K vs. 90K! I guess because I only drive 7-10 k yrly and I look at the difference as 2 yrs. of ownership.
Any words of advice on this is appreciated - On what to look for at this mileage. I know it basically comes down to how the car has been maintained.
Best - CH
Old 12-07-2012, 07:12 PM
aspensilver540 aspensilver540 is offline
Mein Auto: 1997 540i
90-120K about when these cars need major servicing. You know it is about maintenance, so go with your head and look for work done on cooling system, thrust arm/control arm bushings etc
Honestly I would probably pick the car with better paint/interior and do the cooling overhaul myself.
Old 12-07-2012, 07:54 PM
Fudman's Avatar
Fudman Fudman is offline
Service history is the key. Understand what you are getting into. 90 - 110K is the point of major maintenance. A well maintained car is better than a good looking car.
Old 12-08-2012, 05:58 AM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '10 535i '08 X5 '00 528i
With so many M54 engines using a qt of oil every 1500 miles, be sure to ask about oil consumption. Owner should be able to tell you how often they add oil.
Old 12-08-2012, 06:26 AM
Fudman's Avatar
Excess oil consumption is very often due to a failing CCV. The CCV fails due to clogging from oil condensate, which occurs from short drives in cold weather on a cold engine.
Old 12-08-2012, 06:53 AM
BMW CCA 69606
Perhaps, but far too many have changed their CVV multiple times w/o impacting oil consumption....there is something else going on with the M54 engines.
Old 12-08-2012, 07:13 AM
tmvE39/E53/Z32's Avatar
A qt of oil between oil change is normal for M54. I would be more concern with maintenance history of the car.
FS E39 Hella Celis Euro taillights WITH ballasts, for pre-facelift update.
FS OEM E53 X5 Tow Hitch http://www.bimmerfest.com/forums/sho...49#post9981849
Old 12-09-2012, 12:09 PM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
The main areas to keep a eye on are
Cooling System
Control Arms etc.
Window Regulators.
Max
Old 12-09-2012, 01:28 PM
Jason5driver's Avatar
Jason5driver Jason5driver is online now
A bad/ failing Ccv will cause severe problems for the car later on, if not in the near future...
I HIGHLY recommend fixing it ASAP...!
