Old 10-30-2012, 12:09 AM
wthayer wthayer is offline
Mein Auto: 2005 X3 3.0i Manual
Question Broken "Engine Compartment Seal"
I have a 2007 4.8i, but I think this applies to any E70: under the hood at the back of the engine compartment there's a gasket/seal mounted on a long strip of plastic that runs across the width of the engine compartment in front of the firewall right under (touching) the hood. It appears to have been screwed in to the plastic left and right "engine compartment bulkheads" near the middle of the vehicle, but the mounting tabs on mine rotted away and I found the seal just laying on top of the engine the other day. Questions:
- Has anyone else seen this?
- Am I correct in thinking that the CPO extended warranty won't cover this?
- There's a 2011 recall that is related to this part, but it doesn't sound like it my issue, is that correct?
Thanks.
Old 10-30-2012, 12:03 PM
GermanEngineerd GermanEngineerd is offline
Bimmer enthusiast
Mein Auto: 08 x5 3.0si
same with me, i just got an 07 x5 3.0si and noticed this as well.
Old 10-30-2012, 01:02 PM
CALLAWAY845 CALLAWAY845 is offline
Mein Auto: 2007 x5 3.0...2009 328i
Hello Wthayer. On my 2007 x5, this part was totally obliterated by the Arizona sun around 2 years ago. I ordered a part from Tischer, trying to replace it, and only got that long seal that you speak of. I am of the belief that this piece is purely cosmetic, so I have not pursued the fix any further. Thank you for the information on the recall, I will have to investigate that further.
Old 09-07-2013, 10:47 AM
smyles smyles is offline
Mein Auto: X5
Resurrecting old topic: have you found out anything about this recall? Did the brake fluid flush today and noticed the seal just hanging there all by itself... which is kinda lame for German engineering...
Old 09-07-2013, 10:16 PM
badgermountain badgermountain is offline
Mein Auto: 2010 BMW X5 30i
Had mine replaced at 48,000 under warranty. Not sure if CPO would cover it.
Old 04-01-2016, 12:35 AM
Tommyle Tommyle is offline
Mein Auto: 2010 bow x5 4.8i
Engine bay seal
I have 2010 x5 4.8 . Same thing happen to it, that same seal behind the engine broke . The plastic hold the seal broke as well , that seal just basic to prevent the engine noise. Does any one change it or know where to shop for it beside the dealer
Old 04-01-2016, 06:33 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: 2012 Feb 11 X5 35d (E70)
It is vital to our diesels to keep water from intruding under the sound isolation foam. Search is your friend, there is much discussion of repair/replacement and the damage caused.
Post hoc ergo propter hoc is a weak logic akin to arguing from ignorance, "I don't know, but ..." Better to be silent and thought a fool than to babble and remove all doubt.
Old 04-02-2016, 10:11 PM
SoCaLE39 SoCaLE39 is offline
Mein Auto: E60 M5, E46 325i
Replace soon especially if you are in wetter climates.
Old 04-05-2016, 01:04 AM
My 2010 x5 4.8 have same problem , I order parts from ecs tuning and all the part cost about 200 , very easy, it call engine partition , total 3 big part and 2 small part to hold on both side
Old 04-05-2016, 01:05 AM
Thank you, I just find all the part for it
Old 04-05-2016, 01:18 AM
There will be 3 big part and 2 small on both side, the best deal is ecs tuning about 160 total, do it ur self
Old 04-28-2016, 05:39 PM
Arby1028 Arby1028 is offline
Mein Auto: 2007 X5 3.0
Just noticed mine is bad, too. Looks like someone used tape to try and secure it. Anyone have a part number? I've searched Engine Partition and Engine Compartment Seal without any luck at ECS and Tischer.
Old 04-28-2016, 11:11 PM
X5 E70 engine seals compartment
Ecs tuning#es129077=engine partition right/ mfg#51717169420.
Ecs tuning#es129078= engine partition center/ mfg#51717169421.
Ecs tuning#129076=engine partition left/ mfg#51717169419. There are two small part on both side to hold that left and right, and this is the part #es130674. Mfg# 51757171791.partition and es130675. Mfg#51757171792 . Partition and make sure order some screw and plastic rivet
Old 04-28-2016, 11:14 PM
Check my post, I have all the part down for you , let me know if you have any questions, good luck
Old 04-28-2016, 11:18 PM
Check my post , I wrote down every single parts that you need to get , if you have anymore questions, feel free to call me at 714-603-2140, I like to help cause I spend a lot of time to research for this
Old 04-28-2016, 11:20 PM
X5 e70
good luck
Old 04-29-2016, 02:39 AM
good luck
Thank you! This is definitely a future project. Couple questions: mine is currently in bad shape and taped in - is it OK to just take it out temporarily? I'm afraid it may come loose and get caught in a belt or fan. Also, is there a part number of plastic rivets or screws to install it?
Again, thank you.
Old 04-29-2016, 03:21 PM
It ok to take it out, remove the cover, remove air filter on the p/s, un crew some bolt, I'm in California so it not wet , if u r in wet area, u don't want water or to much dirt in to engine compartment , this is the part # for the plastic rivet # es2091819. Mfg#51118174185. It giong to 2 small parts on both side at the end of the seal, I believe u need about 6 it cost $1.49 cent each,the metal crew to hold the middle piece together with both side, I don't have the part# cause my still intact, call ecs tuning when u order so they know or go to dealer , good luck again
Old 04-29-2016, 03:22 PM
Again, thank you.
I'm just posting what you need , let me know how thing work out for you
