E30 (1982 - 1993)
Old 11-20-2012, 03:16 PM
davidspyle davidspyle is offline
Mein Auto: 1987 BMW 325 cpe.
'87 325 Instrument Panel/plus problem
Hello . . .
I'm having an electrical problem with my 1987 BMW 325 and not sure why. The instrument panel is not lighting up, nor are the fuel/tachometer/fuel consumption/coolant temp guages working. Additionally, the heater fan and outside mirror adjuster are not working either. Everything quit, apparently, at the same time.
I've replaced the fuses but the problem persists. Not sure whether it could be a relay or if the fuse box itself is bad. Any suggestions or recommendations as to where to look and/or how to proceed would be greatly appreciated.
Thanks.
David
Old 11-20-2012, 04:49 PM
woodenbmw's Avatar
woodenbmw woodenbmw is offline
Hi David,
I had an issue with my '87 325 somewhat like yours. I wound up fixing it simply by taking the panel out, cleaning the contacts, and replacing the SI batteries. I think it was more replacing batteries than it was cleaning the contacts lol. I hope this helps. Rob
Old 11-20-2012, 05:20 PM
Thanks, Rob.
Unfortunately, I think it is a little more involved than that.The instrument panel guages are not working, along with the fan blower an outside mirror adjusters. So, it would seem that there are other factors. In any case, your response is appreciated.
dsp
Old 11-20-2012, 05:34 PM
downhiller's Avatar
livin large
SI batteries will explain some of the gauges not working. lights are either gunna be the bulbs blew, bad ground, or bad contacts. blower and mirror motors i have nothing.
Old 11-20-2012, 06:00 PM
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming.
Funny, funny. :-)
Old 11-20-2012, 07:13 PM
woodenbmw's Avatar
David
Is this a car you recently acquired or did you have it garaged for a while ?
Old 11-20-2012, 08:15 PM
I've had the car for about four years and have driven it regularly since then. It has approximately 180K on it.
Everything was working until the other day when they all just quit functioning.
Old 11-20-2012, 08:27 PM
woodenbmw's Avatar
I don't think it would hurt to pull the fuse box and look for obvious signs of damage. I'm not completely sure what relays are in the fuse box as I don't have a manual.
Old 11-21-2012, 03:55 AM
BMWFatherFigure's Avatar
Old School
Start checking plugs, contacts and grounds (earths). A large half out plug will bring on all sorts of problems. Check where loom sections join front/rear/engine bay.
Current:
E38 Parts Car
Previous:
