Old 10-30-2012, 12:08 PM
umnitza's Avatar
umnitza umnitza is offline
• www.umnitza.com •
Mein Auto: ///M
••ü•• ProjectorZ II Price Reduction Just In Time for Winter
We have been able to reduce the prices of the ProjectorZ II with Orion V2 or Orion V4 angel eyes. We have lowered the price of the headlights fully loaded by nearly $60, and lowered the price without Xenons by $35 from before.
CLICK HERE TO ORDER
A quick explanation of the options:
Angel Eyes
Orion V2 = Our best value angel eyes kit, almost 5 years on the market, solidly built, slightly bigger LED gaps, bright white.
Orion V4 = Our newest and brightest angel eyes kit, complete with night controller feature, no gaps on LED, factory look.
Xenon:
$30 kit = Standard SuperSlim kit, compatible with ALL Z3 applications
Canbus = Our best 35W kit with no error guaranteed on almost every BMW
Bixenon Retrofit - a true H1 Bixenon allowing you high and low beam off of one bulb
Bulbs:
If you order any Xenon option, you get bulbs for the high beams free
Clear Film:
Good for any cars that are in high salt content areas, road debris, etc.
Pre-Installed:
If you order the Bixenon option, please select the pre-installed Bixenon option as well, otherwise, you'll need to install it yourself.
here are some photos:
CLICK HERE TO ORDER
Join Our Facebook! - Check Out Photos, Talk to Customers, Ask Us Questions!
Call US! 877 486 6489
Available: 9am-5pm M-F
Old 10-30-2012, 12:19 PM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
Old 11-02-2012, 03:25 AM
brock5ga brock5ga is offline
Mein Auto: Z4
For the ProjectorZ4, this is for 2 complete headlamp assemblies, correct? Also, what is the canbus 35W option? On the angel eyes, what is the difference in the Orion light, the Predator Orion V2, and the Multi-color Orion V2? Looking on your site, I do not see descriptions of these items. I may just be overlooking them. Thanks
Old 11-02-2012, 09:13 AM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
http://www.umnitza.com/bmw-3series-c-114_113_1206.html
All angel eyes are described here.
The long and short of it is:
Orion Lite doesn't work on Z4
Orion V2 works great
Orion V4 works even better but costs more
Orion Multi-Color is a multi-color setup.
the product is in stock.
Old 11-02-2012, 06:30 PM
3seriesbmw's Avatar
3seriesbmw 3seriesbmw is offline
Mein Auto: 2003 325i
Z4 projectors need to be marked down!! What are the best options to choose to give it the most stock look when ordering?? I'm not sure if I want to go for a pair of these or repair the original xenons on a Z4 that I am looking at.
Thanks,
3series
My vehicle lineup:
2003 325i-Premium pkg, heated seats, leather (sold)
2005 Chevrolet Tahoe-Navigation, Sunroof, DVD, 4X4, autoride, etc. (sold)
2007 Audi A6-everything except navigation (sold)
2007 z-71 Avalanche-heated seats, sunroof, 4X4 (current)
Also in the garage-
2007 Cadillac Escalade (garage queen) (moms)
2010 GMC Sierra SLT (dads)
2012 Ford F-250 Lariat (brothers)
2004 GMC 2500HD (farms)
Old 11-03-2012, 05:24 AM
Mein Auto: Z4
I am looking to replace a set of the OE Xenon lights with the leveling system. Will these replace them with no error messages and if so, do I need to order any specific options to do so?
Old 11-03-2012, 10:41 AM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
These with a Bixenon retrofit will be significantly better than your headlights unless you already have factory xenons. We have revised some of of the PZ4 Pricing, but not that much
It's unfortunate, but these lights are very expensive still.
Does your car have leveling already? Part of the leveling system on most cars is a suspension based, LCM controlled, headlight leveling system. It's all designed to work in unison.
These however will replace without ANY errors on your car.
Old 11-03-2012, 01:01 PM
3seriesbmw's Avatar
The car has factory xenons although they aren't operational for some reason. Not sure if I should replace the ballast, igniters, or just put an aftermarket set in there.
Thanks,
3series
My vehicle lineup:
Also in the garage-
Old 11-03-2012, 01:58 PM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
You should diagnose them first, it's probably an ignitor.
Old 11-03-2012, 05:11 PM
3seriesbmw's Avatar
What's the best way to diagnose them? How often would water get into the ballast and mess things up?
Thanks,
3series
My vehicle lineup:
Also in the garage-
Old 11-03-2012, 07:05 PM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
water gets in from underneath on some of them, and it's not a ballast issue, it's a bad seal - common on those generation of cars with ballasts mounted under the headlights.
Swap parts side to side, this will require bumper removal in most cases.
Old 11-04-2012, 06:14 AM
3seriesbmw's Avatar
The bad thing is neither headlight works! Is there a way to open up the ballast to dry/clean it out? I might attempt this sometime this afternoon. I'm guessing it would be safe to unhook the battery before I play with these components?
Thanks,
3series
My vehicle lineup:
Also in the garage-
Old 11-04-2012, 10:00 AM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
You don't need to unhook the battery, but you also should be careful working with insulated parts and make sure everything is disconnected prior to starting removing electrical components.
Only thing to do is remove the bumper and the headlights and take it step by step to see which components are a problem.
We use this for viewing how to do certain things:
http://tis.spaghetticoder.org/
Old 11-04-2012, 10:26 AM
3seriesbmw's Avatar
The igniter will click as if they are trying to ignite. Would they be doing this if it was a ballast problem? There is water standing in the bottom of the driver side headlight as well which can't be good!
Thanks,
3series
My vehicle lineup:
Also in the garage-
