Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 8 Series - E31 (1989 - 1999)
Old 10-30-2012, 09:05 PM
cortfitzer cortfitzer is offline
Mein Auto: 735i 1990
Broken Electric Seat
So I just recently bought a 1990 735i. The driver's seat does not work. When any of the buttons are pressed it does do anything. It dosen't even make sounds. What do I do?
Old 02-05-2013, 07:43 AM
jitsjaf2009 jitsjaf2009 is online now
Mein Auto: 1995 BMW 325i Convertible
First check fuses. If they are okay, check under the seat to see if connector is loose or unplugged. if all that is okay, use a meter to see if you have 12volts to the connnector. If not backtrack to see where you lost voltage. If voltage is there, it is a good chance the switch is bad. I have had to replace the switch in two of my three. Friends tell me they two found switch failure common on driver's seat. I wish you luck
Old 03-09-2013, 09:53 AM
twomouse44 twomouse44 is offline
Mein Auto: 1998 740il
have 1998 740il found switch housing broke removed and used soldering iron to put back together switch was good hope that helps
Old 03-09-2013, 10:01 AM
forget to mention if is this problem steering wheel memory will not work either
