E36 (1991 - 1999)
Old 10-30-2012, 09:18 PM
Bimmer1995318ti's Avatar
Bimmer1995318ti Bimmer1995318ti is offline
Mein Auto: 1995 bimmer 318ti
Weirdest **** ever !
So I was driving home and I went to apply my brakes for an upcoming stop sign, a normal amount of pressure applied, I heard a huge clunk and my first thought was my axel was snapped because the noise was occurring with tire rotation, so I checked my axel and it was fun on both side (still at the stop sign, no one was around thank god) and I assumed my brakes locked up, so I was slowly driving home and whenever I touched my brakes the worst noise and vibration came from my front driver side wheel, pulled in my driveway and jacked it up, only to find that my brake caliper bolt had completely disappeared and the noise was my caliper rubbing on my rotor !!!! It's a 3 dollar bolt, and it's a good chance to reprint my calipers anyway, but how did this happen !?!?
Old 10-30-2012, 09:26 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
REpaint means you painted them in the past, right? And how did you reattach them? Did you use a torque wrench and take them to correct torque? (81ft/lbs) That's a lot more than "goodntight". Check the other ones....I'll betcha they aren't anywhere near tight enough, either.
Short version: you didn't get the bolts tight enough. You were extremely lucky.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 10-31-2012, 06:20 AM
Yes it's been about 10,000 miles and the paint has worn a bit, ill torque the other bolts thanks for tip !
Old 10-31-2012, 08:39 AM
nothing.
Mein Auto: ItAintUrShtYUCare?
10k miles and one braking instance couldve killed you.
nothing.
Old 10-31-2012, 12:04 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I'd recommend using some thread-lock on those bolts.
1998 BMW 328is
1966 Pontiac GTO
Old 10-31-2012, 06:25 PM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
looked at the pic wrong.....
i mistook the caliper retaining pin for the carrier bolt. locktite on the carrier bolt has been used by some, gm in particular, so it's not uncommon to see it used.
however, i always like to follow torque specs and make sure the threads are nice and clean.
i hate to torque dirty fasteners...
df
Old 11-01-2012, 05:43 AM
Thanks for the tips guys, it turns out when I bought the bolt at auto zone a while back since the bolt was stripped by the previous owner, it wasn't the reinforced bolt and literally snapped out! Luckily enough I only replaced one bolt and not the others !
