E30 (1982 - 1993)
Old 10-31-2012, 12:27 AM
whaaac whaaac is offline
Mein Auto: 84 325e
E30 VDO gauges
for the e30 gurus,
how do you know for sure that youre odometer and speedometer dont work?
since its a common problem with the e30s, how do you know for sure?
for my 84 324e, my speedometer and odometer works out of nowhere.
its usually dead but once in a while it just works.
is it the wires that not correctly connected or is this the usually problem?
thanks guys!
Old 10-31-2012, 01:48 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
more than likely the plug on the differential is loose
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 10-31-2012, 06:28 AM
BMWFatherFigure's Avatar
Old School
Good first place to check. Then try the dash plugs and earths.
Current:
E38 Parts Car
Previous:
Old 10-31-2012, 02:17 PM
Mein Auto: 84 325e
so my gauges are working correct its just the connection thats bad?
thanks guys!
just to make sure, my gauge isnt fully broken/ stopped working unlike other e30 ones that completely stopped?
Old 10-31-2012, 02:20 PM
Mein Auto: 84 325e
i dont think its the dash plugs.
i honestly think its the plug before whenever (well sometimes) I hit a bump on the road the odometer and speedometer works for like less than a mile and then it stops.
Old 10-31-2012, 02:25 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
My 85' used to do the same thing. Next time it cuts out reach behind and wiggle the connectors to the gauges. Trust me I re-wired all the way from the diff to the cluster, only to find out that the blue connector behind the cluster was just a little loose. I'll hit a bump, speedo cuts out, since I lost my knee cover, I just reach up and wiggle the connector and "wa lah" good to go.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 10-31-2012, 02:32 PM
Mein Auto: 84 325e
so your gauges work properly?
