Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Classic Bimmers
Classic Bimmers
Discussions pertaining to vintage and classic BMW models here...
Old 10-31-2012, 09:32 AM
Olliesup Olliesup is offline
Mein Auto: 1972 Bavaria
Bavaria Clutch problem
Hi there,
My 72 Bavaria has developed clutch problems!!! Started out by loosing clutch pressure (nearly rear ended a car while driving) but regained pressure when I pumped the clutch pedal a few times. When I got back home I checked clutch fluid, level had dropped a bit but no sign of any leak / drips.
With engine turned off I pumped the clutch pedal again and could hear squelching sound coming from the master cylinder. I presume it's safe to assume this is my problem??? Question is now will I get away with a replacing the seals or will I have to get a new unit. Anyone know of where I can get either / both of these?
Also, read somewhere that prob best to change slave cylinder at the same time. Any thoughts?
Thanks for your help.
Olliesup
Old 10-31-2012, 04:26 PM
BMWFatherFigure's Avatar
Old School
Sounds like the master has died. Easy rebuild. Take photo's as you disassemble. Take the unit to a good local specialist. They will have seals on the shelf (OK they do here). May as well do the slave too. Same general instructions. Morning job -Drive in the afternoon.
Current:
Previous:
Old 11-01-2012, 12:18 PM
Cheers for reply. I like your optimism about it being a morning job.... I'm a total newcomer to all this.....but happy to get me hands dirty none-the-less.
Old 11-21-2012, 05:36 PM
BMdude816 BMdude816 is offline
Mein Auto: 2004 BMW 118
I gotta agree with BMWFatherFigure. But if you want some new some Bavaria Clutch Kit check this out http://www.*********.com/parts/clutc...w/bavaria.html . I believe you can find it there at an affordable price without having to sacrifice your satisfaction. Hope this helps, mate!
Old 11-23-2012, 10:10 PM
Clutch slave cylinder needed for Bavaria
Hi, can anyone suggest where I can get a clutch slave cylinder for 72 Bavaria please (externally mounted one)? I've just redone the master cylinder and discovered the slave is also knackered! There are a couple for sale on ebay but they are prced at $230 plus. I read somewhere that the slave off a 2002 while having a slightly smaller diameter will also work; these cost about $50. Anyone out there try this? Thanks.
Old 11-24-2012, 04:34 PM
Hi Olliesup,
Try browsing at partsgeek.com . I saw some slave cylinders sold at low prices. Some are priced below $100. Hope it helps.
Old 11-24-2012, 04:35 PM
Hi Olliesup,
To the mod: Kindly delete this double post.
Old 11-25-2012, 08:35 AM
Thanks BMdude,
Checked partsgeek.com but the ones listed are the "internally" mounted slaves. The one I need is externally mounted and for some reason costs 4-5 times as much. Will keep searching....
I'd also be interested to hear from anyone who has ideas on whether a slave for a 2002 could be adapted to fit?
Cheers
Olliesup
Old 12-23-2012, 04:07 PM
For those interested, I took a chance and fitted a slave cylinder for a 2002 onto my Bavaria. Cost quarter the price ($40 v $200) and works perfectly. Only difference is its about 2 mm narrower than original and I had to wedge some light pieces of metal into the gap to hold it in place. So far so good....
Old 01-14-2013, 01:31 PM
Old School
Use washers or shape a correct thickness spacer. I'm suprised your brake shops dont have a re-sleve service for cylinders. My daughter did her Mustang master for about $50.
Current:
Previous:
