Old 11-01-2012, 09:03 PM
tiger1014 tiger1014 is offline
Mein Auto: BMW 2012 X5 5.0
2012 comfort access problem, please advise
I have a 2012 x5 5.0i, I have 8000km on it, I am experiencing problems with my comfort access, sometimes when I get into the car push the start button (stepping on the brakes)nothing happens, the car does not detect my key, even with the key in my hand, so I have to put the key fob in to start. Half of the times this would happen, its very annoying since I have the fob in my pocket and I sat down already then you push start and it doesn't start,now I have to lean up and get the fob out and put it in the hole to start.I tried putting new battery already the fob buttons always work and all the doors always work just the starting does not, Please help guys!!!!! thanks
Old 11-01-2012, 09:12 PM
henrycyao henrycyao is offline
Mein Auto: BMW X5 35d
Does this happen all the time or at a particular location? Also, were you able to unlock the door using comfort access?
My guess there is something wrong with the radio receiver inside if you can open the door but not start the engine.
2012 BMW X5 Vermilion Red Xdrive35d with Premium Package, 3rd Row Seats, and Adaptive Drive
Old 11-01-2012, 09:20 PM
it happens all the time, anywhere. Yes I can unlock the doors using the comfort access.
Old 11-01-2012, 09:24 PM
I have taken to the dealer already twice, and they are not sure either so they ordered me new fob to try, it will arrive next week.
Old 11-01-2012, 09:31 PM
A new FOB make sense if this only happen with one of two keys you have. I guess BMW really have a bad quality control. I don't tolerate electronic failure because they are so easy to get it right. Low power RF signals are not exactly a rocket science. Its not like they make hundreds of millions of units like Apple or Samsung per year.
Old 11-01-2012, 09:37 PM
its happening to both keys and the dealer check the reception from the car and it was all good, its very frustrating when it doesn't work, very inconvenient, beats the purpose of having the comfort access.
Old 11-01-2012, 11:10 PM
ard ard is offline
Resident Curmudgeon
read this:
http://www.bmwmotorsports.org/pdf/e7...t%20Access.pdf
and this:
http://www.bmwmotorsports.org/pdf/e7...System%203.pdf
The transmitters use one frequeny for access and a different freq for start...
and as you will read this is hugely more complex than 'the battery is low'... indeed I suspect the system has a rich error/code trapping function so that a good (knowledgeable) tech should be able to look at historical codes and failures to figure out what is not working.
GL
A
Old 11-01-2012, 11:50 PM
Thanks, hopefully the next visit to the dealer will have it all figured out and fixed.
Old 11-02-2012, 04:01 AM
denaliman denaliman is offline
Mein Auto: 2013 X6M
It happens to me all the time. It may be an antenna problem. The antenna is located in the A frame running along the windshield that is what the BMW factory tech told me when they ran a diagnostic.
2013 X6M Sapphire Black-current
2013 Audi S4-current
2007 BMW X5 4.8i (E70)-sold
Old 11-02-2012, 04:51 PM
BMW Power's Avatar
BMW Power BMW Power is offline
Mein Auto: 2012 X5 35d
Do you carry the key in the same pocket with a phone? That always causes it to fail for me.
2014 i3 Rex
Retired 2012 X5 35d DSB - Prem, SAV, Cold, Sound, Tech packages, Apps Delivered 6/6/12
Retired 2011 335d AW, M Sport, Premium and Convenience pkg, Heated Seats, Nav, HK, iPod/USB, smart phone. ED 8/31/10
Retired 2008 335i Coupe 6-speed Manual, Montego Blue, Sport, Premium, CW, Nav, PDC, AS, Shade, HD, Sat, Ipod/USB, Logic 7, CA
PCD 11/07
Retired 2004 545i Sapphire Black/Black 6-speed Manual, Sport.
Old 11-02-2012, 11:13 PM
I carried my key with my phone all the time. So far, it has not failed. If it fails, I say it is not functionally as intended.
Old 11-03-2012, 12:12 PM
I tried even just holding the fob and sometimes still fail.
