Old 11-01-2012, 11:11 PM
KaileSvick KaileSvick is offline
Mein Auto: 2003 BMW 745Li
Angry Nasty oil leak, but from where?
I have a horrible oil leak that just sprouted about 2 weeks ago. Approx 1 month ago i replaces the vcg's and timing cover gaskets, and i verified these arent leaking. The alternator bracket gasket is next, but with the amount of oil under my car and in the driveway, i dont think its the only thing leaking. Any suggestions what else could be?
Old 11-01-2012, 11:13 PM
allaboutdaz allaboutdaz is offline
Send a message via AIM to allaboutdaz Send a message via Yahoo to allaboutdaz
Mein Auto: 745
I just fixed a bad leak I had ... It was the o ring seal on the oil filter housing .. You might want to check that as well
BMW 7
Honda S2000
Nissan 300zx TT
SuperDuty F350
Suzuki GSXR 1000
Old 11-02-2012, 04:45 AM
061k 061k is offline
Mein Auto: 05 bmw 745li
I had a leak from an oil sensor on the passenger side, it was leaking where the plug goes in so the cover of the plug made it harder to see where it was coming from
Old 11-02-2012, 09:13 PM
I replaced the oil filter and gasket when i did the other gaskets, but i will double check..Thanks!
Ill look into that, Thanks!
Old 11-02-2012, 09:23 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW 750Li X-Drive
If leak is on passenger side check seals on vacuum pump also.
Old 11-02-2012, 09:38 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
Not trying to hijack but coincidentally i got a bad leak on the passenger side that developed recently and been having a hard time figuring it out, oil pressure switch is it i should check? and i will check the vacuum pump also, definitely not this bad from the VCG i added 2 quarts 1 week ago and had to add again :/
also its worse when the car runs then its parked not as bad when the car is sitting for awhile
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 11-04-2012, 10:59 AM
PRBMW7ser05's Avatar
PRBMW7ser05 PRBMW7ser05 is offline
745i Blk-Blk
Mein Auto: 2005 745i s
Just had my mechanic do some work on my car on Thursday. After the work was done I did a visual and my vacuum pump is leaking. I noticed my oil level being a little low, so I knew something was up. he said it's a $600.00 part. He's checking to see if he can get a deal. He works out of his house on the side. It's easy to see if the pump is leaking. Take the center cover off and look down to your left (engine right). You should see traces of oil residue on the lower pan. Pump also shows oil residue.
Old 11-04-2012, 04:02 PM
wjjklj's Avatar
You don't need a new pump. Just replace the seals. They cost $20. Easy repair. See my post on vacuum pump repair.
Old 11-04-2012, 04:30 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
X2
Sent from my GT-N7000 using Bimmer App
Old 11-05-2012, 10:20 AM
745i Blk-Blk
Thanks wjjklj. I'll give that a look. Everything is expensive on these cars so when you can save money, it's a good thing.
Old 11-08-2012, 07:25 AM
The seals are fairly easy to replace on the pump. Unfortunately that is not my problem. My leak seems to be more concentrated to my drivers side.
Old 11-08-2012, 02:10 PM
745i Blk-Blk
I had that too. It was the oil cooler adapter plate. If your car doesn't have an external oil cooler, they put a plate, with an O ring seal. That starts to leak. It's a good size leak too. The problem is it's behind the Alternator and motor mount on left side. My left side is completely dry now that it's fixed.
Old 11-08-2012, 08:34 PM
Would that be the same as the "alternator mounting bracket gasket"? The little t-shaped gasket?
Old 11-09-2012, 10:58 AM
745i Blk-Blk
That I'm not sure of. My mechanic did the work. It was more then one seal or gasket. I think the major cost is labor. Hard to get to.
Old 11-09-2012, 08:35 PM
mrbmwx5 mrbmwx5 is offline
Banned
Mein Auto: 06 750Li
Check the oil pan seal is a common problem
Old 11-10-2012, 11:24 AM
I have to pull the alternator off anyways to replace the mounting gasket so that is def something ill check.
And OT, could you post a pic of the rear of your car? I see your light are blacked out and I want to know how I would feel about doing the same
Old 11-10-2012, 11:25 AM
It's hard to tell right now, there is a lot of oil runoff from the alternator accumulating on the oil pan
Old 11-10-2012, 06:29 PM
745i Blk-Blk
Don't like this picture because of reflections. I'll take some others.
Old 11-25-2012, 08:42 PM
glesther10 glesther10 is offline
Mein Auto: 760li
oil leak
check your oil pan gasket as well....that was the culprit on my 760li...one thing though the gasket is built into the oil pan.....yep..!
Old 12-11-2012, 12:14 PM
745i Blk-Blk
wjjklj,
In this post I talked about my vacuum pump leaking. You stated it could be resealed. Do you know where I could get the seals from?
Thanks.
Old 12-11-2012, 12:22 PM
745iguy's Avatar
i replaced mine recently:
http://www.bmpdesign.com/product-exe...earch_model/15
PREVIOUS 2002 745i
Old 12-11-2012, 12:30 PM
745i Blk-Blk
Thanks 745iguy. I'll show that to my mechanic. Should work.
Old 12-11-2012, 12:38 PM
wjjklj's Avatar
wjjklj,
Thanks.
I answered your PM but yes try BMPDesign. Kit costs about $28.00 including shipping.
Old 12-11-2012, 12:54 PM
wjjklj's Avatar
Pictures:
TIS included
ID:	352843   Click image for larger version
ID:	352844   Click image for larger version
ID:	352845   Click image for larger version
