Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 11-02-2012, 10:46 AM
kge42 kge42 is offline
kge42
Mein Auto: 740il
Wink Missing after waterpump. radiator change and sparkplug
Hi new member here, I have a 1998 740iI that I replaced the radiator and water pump. In a test drive everything was great, the next time I drove it, it started running rough. Changed spark plugs (Bosh) it was better, but was missing at idle and seems to be getting worse. Seems OK until it warms up. Any ideas?
Thanks.
Old 11-09-2012, 07:48 PM
seamus2154 seamus2154 is offline
Mein Auto: 2001 740I Sport
I would check all of your air intake hoses and clamps. Make sure you didn't crack a pipe. Then move onto the MAF and o2 sensors. Any codes?
Old 11-18-2012, 02:54 PM
BigBoy740il BigBoy740il is offline
Mein Auto: 1991 E30; 2000 E38
You might want to retrace your steps. Is the Check engine light on? Did you have the codes read? You said you changed your spark plugs. Was any of the old plugs covered in oil? Did you replace the spark plug boots? Did you remember to replace the coil pack grounds? When you replaced the water pump and radiator, did you ensure the intake tubes were properly connected (vacuum leaks).
Big Boyz with Bad Toyz.
Old 11-26-2012, 11:41 AM
dUMpEdE39's Avatar
dUMpEdE39 dUMpEdE39 is offline
yee!
Mein Auto: '01 740iL
+1 on checking the coils
R.I.P.
'00 528i Sport, Premium, NAV, Depo headlights, M-style bumpers and mirrors, KW2 coilovers, Eisenmann Exhaust with resonator delete, 19-inch Axis Milano's (staggered), 2 12" Infinti subs, Power Slot rotors, and a trunk full of Dynamat.
Old 12-01-2012, 01:57 AM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Missing
My suspicion is that your head gasket is leaking because if you also filled your cooling system with fresh anti freeze the new anti freeze has found a weak spot in one or both head gaskets.
Old 12-02-2012, 11:29 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
If it's misfiring that badly, there should be codes.
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
Once you have the codes, go here:
- How to diagnose a BMW engine misfire (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
HTML code is Off
