Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 11-02-2012, 11:40 AM
elester12 elester12 is offline
Mein Auto: Pinto
Anyone Have The Follow Fault Codes?
Hello all,
My check engine light comes and goes normally but has finally decided to stay on. I scanned it with my bavarian technic tool and found the codes 4D02 and 4804. It's in German but translated it says, "Reducing-agent pressure buildup".
Anyone know which SCR pipe would have the buildup? I've about had it with this car.
Old 11-02-2012, 12:41 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d
Have you had the recalls done? If not, get it done - they change the injector. If yes, you should be covered by BMW's warranty on replacement parts.
If you're below 70K miles and in one of the 13 CA emissions states (Maryland is one), you're covered, too.
Old 11-02-2012, 05:00 PM
GreekboyD GreekboyD is online now
Mein Auto: 2009 BMW 335d
Closest fault codes I see on the list are:
4D03 Exhaust Backpressure Sensor Bank 1
4803 Torque Control ACC
480A DPF -Bank 1
I'd say it's related to your DPF.
Old 11-08-2012, 10:42 AM
Mein Auto: Pinto
Fault codes 4D02 and 4804 are related to the urea pump under the rear of the car. The pump was not building up pressure. You have to drop the exhaust to get to the pump above the tanks. 6 hours of labor plus 300 ish for parts if you have this done out of warranty at a BWM dealer.
I'm praying for a service manual to be written for this car.
Old 11-08-2012, 06:21 PM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
Extended warranty, get it!
Old 02-08-2013, 07:29 PM
quasimodem quasimodem is offline
Mein Auto: 2009 335d
Hello all,
I cant figure out what 4804 is and I have it showing. I also have 4A66 and 4B90. The first appears to be Power Management Vehicle Electrical system (maybe an old battery) and the second is Rail Pressure Control at Engine Start.
Yikes. Any idea what parts need to be replaced, the entire DEF pump? Or just a valve cleaning?
Okay, see ETK printout below. I see two main suspects -- the pump unit (16197205041 $507.84 at Tischer) and the Supply Module (16197244137 $299.45 at Tischer), any guesses as to which would be causing a 4804 fault code?
HTML code is Off
