Upgrade my E46 to F30? Worth it? Anyone disagree? - Page 2 - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 11-03-2012, 04:43 PM
Chris90's Avatar
Chris90 Chris90 is offline
Mein Auto: '04 330i
Originally Posted by SJBimmer View Post
The new BMW's have jumped the shark. The new 4 cyl. turbo is a good engine, but it has a PLASTIC oil pan. I wonder if it has to be changed at 60K like our cooling systems?
I doubt any F30 buyers plan to keep it past the 36th month of their lease.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression
Old 11-03-2012, 04:48 PM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
Not worth it. An older BMW is still a BMW and still better than most cars from other manufacturers.
Member No. 470379
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Yep.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 11-03-2012, 07:47 PM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
Best thing to do is get an F30 m-sport, I4 or I6 turbo w/o the DH and opt for the manual. Definitely a must with the I4. Then do these upgrades, get rid of the run flats with real tires like the Michelin PSS. Swap out the suspension with Koni yellows, Hotchkis sways, H&R sport springs (1/2 lower). If you have the I4, swap the 4 pot front calipers into it from the I6 model. This should get you back to the E46 ZHP driving experience.
Old 11-03-2012, 08:20 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
Its just an oil container. You have a plastic intake manifold, does it need replacing? Not sure I understand the concern here. The OP has no function except to hold oil, like your manifold, it just diverts air, not even close to being related to the cooling system issues on our cars.
Old 11-03-2012, 08:25 PM
r0gue r0gue is offline
Mein Auto: na
What is the DH? I would def get the I6 turbo 335, so the brakes aren't an issue right??.
Wondering what the difference is between the suspension on the sport build and on the M build. Can you explain?
Old 11-03-2012, 08:49 PM
tturedraider's Avatar
Freedom isn't free!!
You really need to spend time in the F30 forum.
Dynamic Handling package - dynamically adjusting suspension system. It is available in all lines of the F30, including the no-line model. The sport suspension on the Sport and M Sport is the same. It is said the DHP suspension is slightly firmer in sport mode than the standard sport suspension.
www.bmwcca.org
Old 11-03-2012, 10:39 PM
av98's Avatar
ZHP = Patlabor
Dynamic Handling package - dynamically adjusting suspension system. It is available in all lines of the F30, including the no-line model. The sport suspension on the Sport and M Sport is the same. It is said the DHP suspension is slightly firmer is sport mode than the standard sport suspension.
+1, DH also has the option to add the active variable steering. When I test drove the 328i sport, then the 335i sport with the DH they weren't much different as long as you set both the same way- Sport+ and DH to sport. IMHO, I can out drive the DH active suspension algorithm and feel a 1/2 second delay. We have lots of threads about this in the F30 forum.
Sport vs M Sport is pretty much the same except for the cosmetic upgrades and better brake pads for the m sport.
Yes, the 335i has the 4 pot brakes up front.
Old 11-04-2012, 03:27 AM
Mein Auto: na
You're right of course. I did spend a fair amount of time on the F30 ultimate info thread. But I need to go wider there. So from checking the BMWUSA site, it looks like DH eliminates the BMW sport/M-Sport suspensions. So def I leave that off.
As I have a basic E46 with no performance package (16" wheels), I'm guessing that I would be less disappointed with an F30 than someone who did have ZHP.
I'll be off to the F30 forum. But one last questions. With an 05 E46 with only 64,000 miles on it and a manual tranny, is this forum a good place to move it when I'm ready or would its market be limited since it doesn't have ZHP?
Thanks to All who answered. I do really appreciate it. I'm looking forward to becoming an active member here. Not sure what ever happened to my old account, but I used to spend some time here a loooong time back when I had my E28.
Cheers!
Old 11-04-2012, 05:27 AM
Chris90's Avatar
Mein Auto: '04 330i
So you're saying the advantage of DH is when it's on the soft settings, not the sport setting?
Old 11-04-2012, 06:46 AM
av98's Avatar
ZHP = Patlabor
Nope, it's when the driver can't exceed it's compensation abilities.
Old 11-04-2012, 11:39 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
If a stone hits the pan at 90. do you think it wil hold up as well as metal? I would say that the engine holding oil is as critical, if not more so than the cooling system holding pressure. Hopefully we can agree that failure of either system, and the average driver ignoring it, will most probably cause major engine damage. I believe the plastic pan is only on the 4 cyl. N20, and not the N55.
Old 11-04-2012, 12:44 PM
TerraPhantm TerraPhantm is offline
Mein Auto: 2005 M3 Coupe
F30's a nice car - definitely more on the luxury side than the E46 - almost a baby 5-series so to speak. I would seriously consider one as a DD to complement the M3
I don't know - it's not like any of the underbody paneling on my E46s were ever damaged in the slightest. A rock would still have to get through those to hit the oil pan - so I wouldn't be particularly concerned
Old 11-04-2012, 01:50 PM
Originally Posted by sjbimmer View Post
if a stone hits the pan at 90. Do you think it wil hold up as well as metal? I would say that the engine holding oil is as critical, if not more so than the cooling system holding pressure. Hopefully we can agree that failure of either system, and the average driver ignoring it, will most probably cause major engine damage. I believe the plastic pan is only on the 4 cyl. N20, and not the n55.
Originally Posted by terraphantm View Post
i don't know - it's not like any of the underbody paneling on my e46s were ever damaged in the slightest. a rock would still have to get through those to hit the oil pan - so i wouldn't be particularly concerned
+1
www.bmwcca.org
Old 11-04-2012, 02:05 PM
Pretty rare for a rock to get through the splash shield and reinforcement plate. I have read of one example on this forum of OP damage and it looked more like a tool mark to me and not a rock. Anyhow, you said maintenance- rock damage- that would be a repair, and not maintenance, which could happen to anything.
