Old 11-02-2012, 06:36 PM
3seriesbmw's Avatar
3seriesbmw 3seriesbmw is offline
Mein Auto: 2003 325i
Another Xenon question! Please Help!
The xenons will not ignite. Both bulbs have been replaced but nothing however the halogen part of the headlight will work (flash to pass?). In that case it would have to be the igniter or the ballast right? It looks as if one headlight has been tampered with before as it doesn't sit flush with the vehicle and the inner components aren't aligned properly. Should I fix these or put an aftermarket xenon headlight in it that has an angel eye in it? If so where is the best place to get them from? Any help will be greatly appreciated!
ID:	348185   Click image for larger version
Thanks,
3series
My vehicle lineup:
2003 325i-Premium pkg, heated seats, leather (sold)
2005 Chevrolet Tahoe-Navigation, Sunroof, DVD, 4X4, autoride, etc. (sold)
2007 Audi A6-everything except navigation (sold)
2007 z-71 Avalanche-heated seats, sunroof, 4X4 (current)
Also in the garage-
2007 Cadillac Escalade (garage queen) (moms)
2010 GMC Sierra SLT (dads)
2012 Ford F-250 Lariat (brothers)
2004 GMC 2500HD (farms)
Old 11-03-2012, 07:40 AM
3seriesbmw's Avatar
No advice on which aftermarket projector to put in the car even?? More often then not is there a problem with the bulb, igniter, or the ballast? Both lights are not operational so I can't swap parts and the car has around 122k miles on it. There is condensation in the drivers side headlight which I need to dry out but what can I use to reseal it?
Thanks,
3series
My vehicle lineup:
Also in the garage-
Old 11-04-2012, 09:19 AM
3seriesbmw's Avatar
Messed around with the headlight some more and both of the headlights are trying to self level as well as the fact that you can hear an audible clicking coming from the igniter I believe on both headlights. If the igniter is clicking it can't be the ballast? The drivers headlight has water standing in the bottom of it that you can't see from looking at the headlight from the outside but the ballast must still be operational if the igniter is getting power correct? How do you get that much water out of a headlight??
Thanks,
3series
My vehicle lineup:
Also in the garage-
Old 11-04-2012, 09:22 AM
3seriesbmw's Avatar
This is the igniter from the drivers side headlight which has the water in it. The passenger side headlight looks new although its sitting in the car..oddly.
Thanks,
3series
My vehicle lineup:
Also in the garage-
Old 11-04-2012, 09:49 AM
dkl dkl is offline
Mein Auto: E53 X5, E86 Z4MC
Are your bulbs OE or aftermarket? It could be that your ignitor/ballast can't ignite that particular bulb?
Old 11-04-2012, 10:29 AM
3seriesbmw's Avatar
I'm not sure as I didn't put the bulbs in the car! I will try to find out for sure though! Is there a way to tell by looking at the bulb by any chance?
Thanks,
3series
My vehicle lineup:
Also in the garage-
Old 11-04-2012, 10:39 AM
dkl dkl is offline
No way to tell just by looking at the bulb...well...maybe. I think the OE bulb should be branded as "BMW"? I believed Philips and OSRAM may also be OE manufacturers.
HID bulbs do not have a filament, but it rely on a high voltage to create a spark between two nodes. If the gap between the nodes are wider than specs, then your ignitor/ballast won't be able to create the spark to light it.
Oh...make you you have the correct bulb in there. I believed that you have D2S.
