E46 (1999 - 2006)
Old 11-01-2012, 09:38 AM
bfinta bfinta is offline
Mein Auto: 2004 325xi
Aux input problem
Hi everyone, first post here i have an '04 325xi, i recently installed the genuine aux input kit from the dealer, installed it in the cubby hole beneath the climate control unit, anyways its been working fine for a few days, all of a sudden today while working in the car listening to the stereo it switched on its own from 'aux' to FM, then i tried to cycle back to AUX and wasnt even an option. tried again and it worked but now it seems when it does find the AUX it only stays on that input for a few seconds and then automatically switches back to FM... any ideas of whats wrong?
Old 11-01-2012, 10:25 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Can only tell you that mine does that from time to time, but I can switch right back to aux and it works fine again. Might be the connectors on the back of the radio are loose, I'd check those leads for starters.
Old 11-01-2012, 10:27 AM
ok i guess ill see how it behaves over the next few days, id prefer to not have to take it apart again. its just the one cable attaching to the back of the stereo... i would have thought with that clip that pushes down it would hold it in place well.
Old 11-01-2012, 10:30 AM
smolck's Avatar
ROLL TIDE!
One would think, but if it isn't working then you have to go through process of elimination.
Old 11-01-2012, 12:32 PM
Gryphon's Avatar
Gryphon Gryphon is offline
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
When it refuses to cycle to AUX, do you have the device plugged in to charge? This can cause a ground loop situation which the head unit changes to save itself.
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
Old 11-01-2012, 10:50 PM
not sure what a ground loop is, but the times it did switch away from Aux to FM it was charging (through USB / cig lighter), tonight it did it again, then i unplugged the charger and so far it hasnt done it while not charging.
Old 11-02-2012, 08:52 AM
Gryphon's Avatar
The Boss of Nobody
Yeah, you cannot charge your device while playing it through the AUX connector. This causes an electrical situation that could damage the head unit so it switches away from that mode to prevent damage. Some of the better AUX IN setups have what's called a Ground Loop Interrupt which will allow for charging and playing simultaneously.
Born 02-24-11
Born 06-22-16
Old 11-04-2012, 04:07 AM
nl318 nl318 is offline
Mein Auto: 318i 2000
You can buy something what's called a ground loop isolator. You just have to plug it in between your 3.5mm wire and you can use aux while charging perfectly!
Sent from my HTC Desire HD A9191 using Bimmer App
Old 11-04-2012, 06:26 AM
thanks for the replies guys / gals... i never thought this would be a problem, for the 80$ i paid for the darned aux input kit you'd think BMW would have known this could be an issue and implemented this device in the kit.
So would this do the trick? http://www.ebay.ca/itm/3-5mm-Earphon...item3a60c689e3
if im not allowed to post links to auctions sorry...
Old 11-04-2012, 07:08 AM
Yes, that's it!
