E34 (1989 - 1995)
Old 11-03-2012, 03:32 PM
e34_spangler's Avatar
e34_spangler e34_spangler is offline
e34 User
Mein Auto: e88 135i
Rear shocks stuck
Rear shocks wont come of I put lowering springs on the front ones but the rears wont come off
Sent from my SCH-I535 using Bimmer App
Old 11-03-2012, 04:38 PM
e34 User
Mein Auto: e88 135i
To be more in depth where you would slide the shock off the brake its like stuck you pull it'll nudge but like pull itself back in
Old 11-03-2012, 05:08 PM
M540FELLA's Avatar
M540FELLA M540FELLA is offline
Josh
Mein Auto: 95 540i m sport
Hit it with a hammer. Also did you remove the bolts from the top deck? http://www.bmw4life.com/suspensionLowellRA.htm
Old 11-03-2012, 07:38 PM
e34 User
Mein Auto: e88 135i
Yeah were using every tool we had to try and smack that thing off but it wont budge any ideas? We did take off everything necasary like on the website
Old 11-03-2012, 07:47 PM
south26 south26 is offline
Mein Auto: 535i 1989
use a pickle fork and a 3lb sledge. It has worked for me every time.
Andy
Old 11-03-2012, 08:16 PM
My525iT My525iT is offline
Mein Auto: 92 525iT Wagon M50
Never had a problem taking one off. However when reinstalling it I will use a car jack (non BMW) and place it under the lower deck and raise it just enough to slide the lower shock mount on. Maybe this technique can aid in removal. Jack it up slightly and tap it off.
What is the orange toggle switch in the pic for?
Old 11-03-2012, 08:18 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
I like that proposed solution
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-03-2012, 08:41 PM
e34 User
Mein Auto: e88 135i
My friends a mechanic well family buisness kinda new to it but we had the car up on a lift but idk I guess will figure it out
Old 11-03-2012, 09:04 PM
BMR_LVR's Avatar
Humble E34 lover
But having it up on a lift with the weight of the suspension hanging is perhaps what is loading the shock mount (downward).
If I understand My525iT's suggestion below, he is saying that the car can be suspended (either with a lift or jack stands), but have it low enough to the ground that you can use a jack underneath the section with the lower shock mount. This will unload it enough to perhaps be able slip the shock off.
It's worth a shot. Either way, good luck and please do let us know how you get it off once you do.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-03-2012, 10:21 PM
M540FELLA's Avatar
Josh
I just changed out my rear shocks and springs today for coilovers today actually. Didn't have any problems getting mine off, but like metioned above there needs to be a jack under the rear trailing arm to support it. The bolt is completely out right?
Old 11-04-2012, 04:05 AM
If they rust they will not come out even if you use a sledge on them to remove them. I have beat one until the shock was flat. Like I said the pickle fork will get the shock out.
Andy
Old 11-04-2012, 07:52 PM
e34 User
Mein Auto: e88 135i
Ok thanks guys were gonna try on the rears again tomorrow so ill try the jack idea thanks!
Old 11-05-2012, 04:02 PM
e34 User
Mein Auto: e88 135i
Just wanna let you guys know that we got the shocks off took an air chisel at the metal it came off right away and new springs feel and look a lot better then stock!
Old 11-05-2012, 04:09 PM
BMR_LVR's Avatar
Humble E34 lover
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-05-2012, 04:29 PM
M540FELLA's Avatar
Josh
Pics or it didn't happen!
Old 11-05-2012, 05:20 PM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
I was going to suggest to heat it up and hit it but air chisel probably split that thing open like butter.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 11-05-2012, 06:01 PM
e34 User
Mein Auto: e88 135i
Ill get pics of what I got didn't take much really
Old 11-07-2012, 06:18 PM
e34 User
Mein Auto: e88 135i
ID:	348713Click image for larger version
ID:	348714Click image for larger version
ID:	348715Click image for larger version
There's picture of old/new ride height the new springs and the csr on the lift.
Old 11-09-2012, 05:26 AM
SwissCheeseHead SwissCheeseHead is offline
Mein Auto: 08 G37,94 530i,11 328iT
So the new ride height is on the left and the old is on the right? Are those eibachs? IMO needs moar low.
2008 Infiniti G37, 1994 BMW 530i, 2011 BMW 328iT
Old 11-09-2012, 06:10 AM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
Andy
Had to do the same with my five speed a few months ago. I sprayed it down with plenty of WD-40 and just went at it with the forkinhammer (Pun intended)
Now I need to replace the fronts on my Benz. No springs to deal with :o))) That baby has torsion bars in the front...
Old 11-09-2012, 11:16 AM
e34 User
Mein Auto: e88 135i
I only payed 85 bucks brand new there from st supsensions and for 85 bucks I was like alright sounds good haha and yes I say it stoped like a half a foot on the front
Old 11-09-2012, 11:36 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
I agree with MOAR low. does look good though. I'd be wary of off-brand, cheapos though...
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 11-09-2012, 03:00 PM
e34 User
Mein Auto: e88 135i
St suspensions is pretty good got warrenty and all
Old 11-09-2012, 03:49 PM
Monsignor's Avatar
Mein Auto: Sig
That works too haha
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
