Old 11-03-2012, 06:39 PM
Teamchil Teamchil is offline
Mein Auto: 2012 F30
Exclamation 2012 F30 Radio Wiring
Hi, I have a 2012 328i and I have changde out all the door speakers cause the Ultimate Driving Machine does not have a good sound system
I'm hoping to find out which wires coming off the back of the basic radio unit are to which door speakers. I have to change out the speakers and want to add a amp. Would like to tap back into the factory speaker wiring so I dont have to rerun wire through the doors.
So if anyone can help me find the wire colors that would be great!
Old 11-03-2012, 06:51 PM
floydarogers's Avatar
Pedant and Curmudgeon
If the F30 is anything like the E46 & E9x, good luck.
There has not enough room in the dash for an amp: BMW puts them in the trunk, and it's an entirely different wiring system for that. I'm not even sure that each speaker has a different color. There is probably not a pre-amp out on the head, either, since BMW uses a fiber-optic system for the separate amps in the trunk.
And besides all that, the 3" door speaker hasn't really been the problem; it's been the under-seat woofers.
I would re-think what you're upgrading before you begin. This is a very complicated system.
Old 11-03-2012, 07:10 PM
Mein Auto: 2012 F30
Floydarogers, Thanks but I'm more that capable of tackling this, especially since I have already replaced all the door speakers and have removed the head unit to look at what wires are already there. There is not fiber optic in my car for the stereo and you are right there is no room for a amp in the dash but no one said anything about putting one in there. The speakers are 4" and the factory speaker where some of the worse Ive heard for a factory system which really surprised me. Do everything was way easier than I thought it would be too, doors pop right off and the radio is 4 screws and out.
photo 1
Factory speaker on the left
photo 2
photo 3
photo 4
photo 5
But if anyone else and help me with my wiring color question that would be great.
Old 11-04-2012, 04:30 AM
KLC KLC is offline
Mein Auto: '13 335i Sport
Use a multimeter to figure out which wires go where. That will take 10 minutes.
ED - 5/13/2013
PCD - 7/17/2013
2013 335i Sport Line PPK | Alpine White/Coral Red | ZDH | ZCW | 2TB | ZTP | ZPP | 508+3AG | 5AC
Old 11-04-2012, 04:39 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Your speakers are connected to an either 7ch-(HiFi, analog) or 9-ch (Top HiFi, digital) OEM amp in the trunk. Your iDrive unit is connected to the OEM amp either by copper (HiFi) or fiber optics (Top HiFi) cables. There are no speakers connected directly to the iDrive unit in the USA.
Please search as this has been discussed many times before.
Old 11-04-2012, 04:45 AM
Technic's Avatar
Mein Auto: 2017 M3
Considering that removing the iDrive unit can take some 15 minutes (if required at all), removing the left trunk liner another 10 minutes, each door panel is another 10 minutes each, the center speaker trim some 5 minutes and then probing each wire -with a very long probe- about 2-minutes each, I just cannot see how this is a 10 minute job...
Old 11-04-2012, 10:34 PM
jlukja jlukja is offline
Mein Auto: '13 328i
photo 1
photo 2
photo 3
photo 4
photo 5
Is your replacement door speaker able to clear the glass when the window rolls down?
MY2013 328i, N26 / 300 / 4CG / KCDF / 2DW / 205 / ZDH / 302 / 3DZ / 403 / 494
Old 08-14-2013, 04:24 AM
F30 SA F30 SA is offline
Mein Auto: F30 320i
Hi. I cant quite recall the exact colours for each door.
But the way i worked it out was by removing door sills and lifting up the carpet. The speaker wires can be seen entwined . Suggest connecting from amp at these locations so head unit removal would be avoided toi. Easier infront as there is a tyco connector. Remember tho that front doors and underseats run off front channel and are full range. Rear doors tho are limited in that they dont go low enough for.bass.
Hope this helps.
Everyday
Weekend madness
328i, electric, f30, nav, radio, stereo audio wirint, stereo wiring, wiring
