E36 (1991 - 1999)
Old 11-03-2012, 06:59 PM
4D_E36 4D_E36 is offline
Mein Auto: 1995 Bmw 325i 4door
Transmission and Engine Crank Problem!!!!
Hey, I recently about a week ago put a new engine in my 325i. Me and my friend noticed a little problem but thought nothing of it. We were installing the automatic TM on the new engine. It came with a clutch and flywheel from a 5 speed trans but of course I had to swap everything auto off the old engine. We noticed that without the transmission on the crank spins perfect, but when we install the trans it makes a click sound and never crank up. It don't even spin. If anybody know the answer I would be greatly appreciate it. Thanks.
Old 11-03-2012, 07:25 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
sounds like a weak battery to me...is it fully charged?? 12.6v is a full battery. 12v may not be enough to engage the starter. check it with a dvom.
df
Old 11-04-2012, 12:51 AM
I also noticed I didn't have the transmission torque sensor connected? That battery is also 1 year old. Oh and do it matter if when I had the engine and transmission out I spin the crank with a socket wrench and it turned but when I put the transmission on and spent it it barely moved?
Old 11-04-2012, 12:14 PM
no....none of that, including the age of the battery, matter when it comes to checking the basics, which would start with the state of battery charge.
df
Old 11-04-2012, 02:58 PM
hornhospital's Avatar
D'oh, You Kids!
Sounds to me like you have the engine/transmission/torque converter in a heck of a bind somehow. Are you sure everything was meshed together and not crushed when you tightened the bellhousing bolts? It's easy to bind up the torque converter if it doesn't engage the transmission input shaft correctly.
Sent from my MB860 using Bimmer App
Quotes to live by:
Old 11-06-2012, 06:17 AM
Yes I'm sure everything was carefully done. I also got the new battery but still dose a click and don't turn over. I also tried turning the crank with a 19in socket with my breaker bar and still nothing, it wouldn't budge. Any other suggestions?
Old 11-06-2012, 06:38 AM
D'oh, You Kids!
Bite the bullet and pull the transmission to see what you've got bound up, because something is definitely bound up between the crankshaft and transmission. If you can't turn it with a wrench on the crank pulley bolt, it's never going to spin over with the starter.
No transmission/torque converter connected: engine spins freely
Trans/TQ attached: engine won't spin
It's pretty obvious something isn't attached correctly.
Quotes to live by:
Old 11-06-2012, 06:58 AM
Ok I will try that and see what happens. There's one thing I did have a problem with and it was this metal triangular shaped deal and it was kind of bent but it was easy to put back into place because it wasn't extremely bent. Idk if that's the problem too but it spins great without the transmission on.
Old 11-06-2012, 07:10 AM
Oh and what about the torque sensor? Would it matter connecting it or not when cranking the engine?
Sent from my HTC VLE_U using Bimmer App
