Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F07 Gran Turismo (2010 - Current)
The 5 Series Gran Turismo -- now available in the USA as a 535i, 550i and 550i xDrive model.
Old 11-08-2012, 11:04 PM
ronin550 ronin550 is offline
Mein Auto: BMW 550i
Speed Limiter on 550??? Dead Key battery??
Hi, I was driving my 550 and pressing the gas down to see the speed. As my speed was increasing, nothing crazy, I think 105-110 a symbol popped up stating "LIMIT". The symbol popped up near my dials.
Does anyone know what this means?
Also, I have key less entry and all that go stuff. I don't need to plug my key into the ignition either. But when I start my car by pressing the button, there is a picture of a key and it looks like it is telling me the key's battery is dying. Can anyone tell me what this picture actually means and what I should do?? THanks.
Old 11-08-2012, 11:21 PM
SimiClyde SimiClyde is offline
Mein Auto: 2013 535iX GT
Yes, replace the button battery in the key fob.
2010 535i: Deep Sea Blue | Natural Brown | ED: 6-Aug-2009 | 2013 535iX GT: Neptune Blue | Venetian Beige | ED: 31-Aug-2012
Old 11-08-2012, 11:23 PM
Going out on a limb here -- the car was warning you that you were exceeding the speed limit?
Old 11-08-2012, 11:37 PM
Mein Auto: BMW 550i
What I meant was, us there a limiter on the speed? Or was it just a warning that your speed is high? All it said was "LIMIT"
Old 11-08-2012, 11:39 PM
Mein Auto: BMW 550i
How do you replace the battery on the key fob? The salesman at BMW told me the key chargers inside the ignition if you plug it in. I did that, but the symbol keeps popping up.
Old 11-09-2012, 07:07 AM
The cars with Comfort Access do not charge the keys. This has always been the case, so shame on the salesman for not knowing his product.
The key fob styles have changed a bit over time, so your best source of info will be the manual, which can be downloaded from the BMW web site (that's a bit of a PITA, but can be done).
For example, the key fob for my 2010 E60 has a little "door" on the back that can be pried open, after you remove the key from the fob (had to change it's battery at ~ 3 year mark).
The fob for my F07 is decidedly different -- it looks like it might also pry open, but I've not needed to change the battery yet, so haven't fiddled with it.
Old 11-09-2012, 07:14 AM
If I understand the feature correctly (big if, as I don't have it) -- some cars have a subsystem that tries to glean the posted speed limit from road signs, and then generate appropriate warnings. You should try to get a complete dump of what your car is equipped with -- give the site: bmwvin.com
You should be able to get a good read on what your car's packages / options are, and from there be in a better position to research the capabilities of specific features....
Old 11-09-2012, 01:37 PM
Mein Auto: BMW 550i
Guys, I'm new to this forum but I wanted to say thank you for all the information! Much appreciated!! This is very cool!
Old 11-09-2012, 02:19 PM
lexhair lexhair is online now
figuring out my iDrive
Mein Auto: '11 535 GT xDrive
Instructions are in the manual. I changed the batteries in the two fobs I have. Not hard at all.
1. Take the integrated key out of the remote control.
2. Push in the catch with the key.
3. Remove the cover of the battery compartment.
4. Insert a battery of the same type with the positive side facing upwards.
5. Press the cover closed.
Old 11-10-2012, 07:57 AM
Fish23 Fish23 is offline
Mein Auto: BMW 535xi GT
Lex is correct. I had to do the same thing with one of my fobs and decided to do them both.
Check your iDrive. In Settings, scroll down to 'Speed' where you can set a 'speed warning limit' which reminds you that you have exceeded it which is easy to do on the highway. The previous owner likely set it and that is what you are seeing and hearing. Find the setting and uncheck the box and it should not re-occur or set it to a speed at which you want a warning. Good luck.
Old 11-10-2012, 08:20 AM
The BoatMan's Avatar
The BoatMan The BoatMan is offline
Bayerische Motoren Werke
Mein Auto: '12 550I GT/ '10 Golf TDI
From your description sounds more like the speed limit warning and not the speed detection. Speed detection is more of a square with the speed inside.
As noted above, Speed limit warning is a user set feature:
idrive - settings, speed, warning at, and enter what you wish or turn off.
If you have the speed limit detection feature it will be listed here:
idrive - settings, info display, speed limit information
And btw there is a top speed limiter. I think its 150mph but could vary based on model and packages. Go to bmwusa and look up your model to be sure.
Current:
2012 550I xDrive GT
2010 Volkswagen Golf TDI
Gone but not forgotten:
2009 X5 35d
2007 335i European Delivery with Performance Center Re-Delivery * ED May 4, 2007 Link to ED Trip Report / PCD July 5th, 2007 Link to Performance Center Re-Delivery Trip Report
2007 X3 European Delivery with Performance Center Re-Delivery
2002 330ci, 1997 328i, 1990 325i
Old 11-10-2012, 09:13 AM
Mein Auto: BMW 550i
Boatman! Thanks for the information. I'm new to the forum but I am loving all the information and assistance people provide. Thank you again!
Old 11-10-2012, 11:29 AM
Boatman is correct. I mistook limiter for warning. My apologies.
key battery, key charge problems, key issues, limiter, speed limit, speed sensor
HTML code is Off
