E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Hi Guys
So Was out with my step son with the roof down and all was well. Parked the car, put the roof up , no problem and went to see a movie. Came out and the roof didn't move at all. In fact the lights on the pannel didnt event light up. The windows don't go down when you push the "roof down" switch and I checked the switch in the trunk and it seems fine. correct me if I am wrong but if the windows dont budge and the lights dont come on when pressing the button, it would possible indicate that its a fuse issue and not a motor issue ? the windows work fine when using the window controls. Thanks |
I would look at the fuses for sure. Good luck.
Same problem had on the Porsche Boxster.
Remove the relay let it loose current for a while and then put it back in. Hopefully this also works for you. This sounds funny but it did work. Why it works I don't know. greetings Guus |
Hi guys. An update. Still no luck. I checked the 3 fuses and all look ok.
It's something electrical. Because the light on the switches don't even light up when pressed. Any other ideas ? |
We need some more info. What year is your Z? There are a lot of posts on here about troubleshooting and repairing the soft top motor, but let me send you direct to the expert: Shipkiller
It's a 03 2.5.
Rarely a fuse, probably your soft top motor is dead. They are subject to corrosion from water draining into the soft top drains and the left drain being clogged. Very common problem. Check out the Shipkiller web site I posted above. A BMW dealer will charge you at least $3,000 to replace it and an indy shop probably anywhere from $1,600 to $2,500. DIY and save big bucks, but it will take some skill and determination. Good luck.
Thanks for that. My question is if its the motor wouldn't the windows still try to go Down or the panel buttons light up on touch. ?
Thanks again |
I agree with you, if the windows aren't going down and you're not getting any of the typical lights I'd look elsewhere first. Why don't you try disconnecting the battery and seeing if that resets...whatever needs resetting.
Tried that, still nothing.
You need dealer intervention, or someone with the BMW INPA software so you can get a good, reliable diagnoses.
Based on the limited information you have provided, sounds like the softtop control module is bad. This is a very rare thing but can happen. The only way to know is to have it checked out. A faulty motor will give you error lights. So too if any of the four Hall Effect switches are faulty or one of the harness's is broken. PS: SEARCH is your friend....
. How does something immoral, when done privately, become moral when it is done collectively? Furthermore, does legality establish morality? Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of more people. Walter E. Williams Drives a 2008 Z4M Coupe' (His) & 2003 Z4 Roadster (Her's) |
Roof won't work
Hi
Trust me, it will not be the fuse.(I've still not found it) As some have said it may be the motor. I live in Australia. A 6 hour drive to a BMW dealership. Try this if you haven't all ready. Read your manual, and open and close the roof manually. Sometimes the senors and the computer get all confused and this resets everything. This fault occurs often. I hope that helps. Good luck. gymm. |
gymm,
If you have to do what you propose more than once, then that is indicative of another issue in the softtop. Yes, the problem is intermittent and what you do 'cures' it, but it is not right..... The softtop module seldom, if ever gets 'confused'. .
This is a common problem with these cars. The drain holes for the top get clogged and the top motor is soaked in water and shorts out. I had my top motor replaced a couple months ago at my BMW Stealership at a cost of $1.400.00 parts and labor. I will keep a close eye on those drains holes from here on out !
Ok here is the update. It's not the motor , not the modules , not the fuses. Looks like there is a leak from the ram or a hose. The reason the lights on the switch are not showing up and indications at all is that the system is confused as the roof is in a state of limbo.
So it's a 5 hour job to get the roof off to check for the leak and hope its just a hose. The weird thing is that I never saw any oil on the driveway. Could just have been a slow leak. Will update in a few weeks. Pat |
I'm going to ask for the old pump back, so I can rebuild it for next time. |
Curious to hear the outcome. Never heard of an oil leak causing the roof not work, especially since there is no oil in the rear of the car, of course except diff oil. Maybe is was the hydrolic fluid for the top motor.
| Bookmarks |
| Tags |
| convertible, fuse, roof, stuck |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
