Old 11-21-2012, 04:09 AM
ISIS27 ISIS27 is offline
Mein Auto: 2006 750Li
What Parts are needed to Repair the L7 AMP (INPUT NEEDED PLS...)
Hey guys, Im new to the forum, although I have been on here many times, the amount of info that I have been able to find on here is incredible.
Anyway down to the nitty gritty. I have an 06 750Li and have the Infamous L7 Amp issue. I've read all the threads and DIY pages but im a bit confused and was hoping someone could clarify.
I have all the tools needed to fix this bad boy minus the parts, Im confused as to which parts I actually need as I have seen several part numbers floating about.
Can someone provide a parts list of Transistors that I need to order so I can fix this amp please.
This is what I have found:
KT3107- is this for the amp fan?
TDA8563 & TDA8564 - I have seen both of these referred to as the transistor that controls the rear door speakers. Which one actually is it?
TDA4562 & TDA1562 - I have seen both of these referred to as the transistor that controls the under the seat subs. Which one actually is it?
Center Speaker - Im not sure what the transistor part number is for this one.
and are there any other parts I should swap while at it?
papers
